How long do shocks last?
Old Feb 27, 2011 | 09:32 PM
godzilladude's Avatar
godzilladude
Default How long do shocks last?
I added Bilstein Sports at around 10K. Now I'm almost to 50K, and there is some weird squeaking coming from the left rear when the car bounces good.
Old Feb 27, 2011 | 09:39 PM
RicK T's Avatar
RicK T
Shocks should be fine. Might look at the sway bar bushings and end links.
Old Feb 28, 2011 | 07:13 AM
tomiboy's Avatar
tomiboy
On a similar note...how long do the stockers last (Z51)
Old Feb 28, 2011 | 08:54 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I'm at 101k on my '07 Z51 and the shocks are still good. Yes, I will have to replace soon. Noise is probably from the sway bar bushings as someone stated already.
Old Feb 28, 2011 | 08:56 AM
KarlK's Avatar
KarlK
From: Beats UD regularly playing 3D chess, and at life
I'd check end links and sway bars a stated above.
If that isn't it, check the upper shock bushings.
Old Feb 28, 2011 | 12:25 PM
3 Z06ZR1's Avatar
3 Z06ZR1
My 2008 base car shocks were toasted at 17k. All 4 had a couple inches of slop. Worst factory shocks I've seen. Replaced them with the
Z-51 shock and springs.
Old Mar 1, 2011 | 10:18 AM
godzilladude
I'll check out those end links and bushings. Thanks!
To How long do shocks last?
