cheapest camshaft?
Old Feb 28, 2011 | 03:14 AM
david2613d's Avatar
david2613d
Default cheapest camshaft?
what is the cheapest camshaft that will gain you the most horsepower?
a6-c6 2008
Old Feb 28, 2011 | 04:46 AM
Quijeeboe's Avatar
Quijeeboe
The camshaft is not the most expensive part of the cam swap. If you are not doing the installation and tuning yourself, the labor will almost certainly be more expensive than the camshaft. Additionally you're going to likely need new valve springs, and you'd be wise to swap your timing chain while you're at it.
In short, there is more to it than just popping a new camshaft into the motor. So get ready for a bigger financial hit than was likely initially anticipated.
Old Feb 28, 2011 | 07:12 AM
tomiboy's Avatar
tomiboy
I think there all about $400, unless you buy a Z06 or Zr1, then about $150 but alot less gains
Old Feb 28, 2011 | 10:43 AM
LEAVINU's Avatar
LEAVINU
with the two above post. If the camshaft cost is of concern then maybe you should consider saving a bit longer. At $400 for an aftermarket it's definitely the cheapest "single piece" you'll buy that makes good power.
Last thing you want to do is go cheap on parts with a cam swap. Do it once and do it right; otherwise you'll be shopping for a new shortblock after awhile.
Old Feb 28, 2011 | 12:43 PM
gunterwalker's Avatar
gunterwalker
From: Cape May, NJ; Guntersville, AL; Orange Beach, AL
Getting cheap with the Vette = Bad Idea. New cam shaft total is usually around $3k after install.
Old Feb 28, 2011 | 12:49 PM
timd38's Avatar
timd38
Even if you do the work at home, it is not worth the pain of using a pre-owned or low cost cam.
Old Feb 28, 2011 | 01:03 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
Once you start moving into the aggressive ramp rate cams, the parts list will escalate. Most cams are in the same price range of $360-$399 depending on vendor. Then, you will have to add dual valvesprings and hardened pushrods. The cam swap kit usually runs $699-$725 for the hardware, depending on vendor. Of course, that is the bare minimum and you never want to do that. It is a good idea to replace the timing chain, all gaskets, and timing chain tensioner.
Then, you will need supporting mods like headers and CAI to take full advantage of the cam. No point in getting a beefy cam and have the exhaust choke it. If you are not installing yourself, add a ~$1k for the install and a few hundered more to tune it. There is no such thing as a cheap cam swap.
Old Feb 28, 2011 | 01:07 PM
breecher_7's Avatar
breecher_7
Very much the truth. A Z06 cam will get you decent gains but for the hassle involved in doing the swap, its worth it to shell out the extra cash for a better cam. The parts alone for the cam swap arnt bad, sub $1500 all day long for everything you need. But if your not capable of doing the tuning or the install thats where your going to take a hit. Most places charge around $800 to do a cam swap and around $500 for a tune.. So a huge chunk of your money will get tied up there if you cant do it yourself.
Old Feb 28, 2011 | 08:32 PM
Blorton's Avatar
Blorton
You want cheap? Go with higher lift rockers and leave your stock cam in place.
Old Feb 28, 2011 | 09:26 PM
dads toy's Avatar
dads toy
you want to put cheap in your 2008 vette? good luck to you.
Old Feb 28, 2011 | 11:36 PM
hungryhippo's Avatar
hungryhippo
try the flea market
Old Mar 1, 2011 | 04:14 AM
keyplyr's Avatar
keyplyr
Tough room
Old Mar 1, 2011 | 08:48 AM
eric04's Avatar
eric04
if you plan to go cheap dont go there at all. its better to spend a little more now then a lot more later.
Old Mar 1, 2011 | 09:22 AM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
The cheapest camshaft is one that you install and get the results you are looking for and NOT have to change it out again. I would look for the correct camshaft for your application and then shop around for the best price on that particular camshaft.
Old Mar 1, 2011 | 10:49 AM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
As mentioned, the cam "kit" will cost you around $1500 give or take a 100 on either side.
Cam, springs, pushrods, NEW timing chain (Katech C5R at the minimum)
gaskets/seals, Under Drive pulley?, new oil pump?
How many miles on your 08?
To cheapest camshaft?
