CAM Selection for my LS2
Old Mar 2, 2011 | 09:08 PM
KOTYKB's Avatar
KOTYKB
Default CAM Selection for my LS2
Below are the current modifications I have on my 2005 C6 6-Speed Vert. I'm looking for a CAM package that I'll be installing myself. I want a CAM that's reliable, gives me a good increase in HP, doesn't surge when I'm in 6th gear @1500 rpm, and has the distinctive CAM sound at idle.
- Vararam Intake
- Spinmaster Ported Intake/Throttle Body
- 180 Degree Thermostat
- LG Headers with High Flow Cats
- Full Corsa Exhaust
- Doug Rippie Dyno Tune
382 RWHP
I contacted Thunder Racing and this is what they recommended-
Thunder Racing CAM Package ~$1000 for CAM, Springs, and Rods
"TR TRuTorq" Level 2 - 223/230 .609/.604 115 LSA
Do I need a high performance oil pump?!?
http://www.thunderracing.com/shop-by...388.html#P5278
Thanks!
Old Mar 2, 2011 | 10:25 PM
Ragtop 99's Avatar
Ragtop 99
That's a mild cam and should be easily tuned for no surge at 1200 rpm. You have a DRM tune now. If he will be doing the tune for you, ask him. He should know what size cam he can tune to meet your requirements.
Old Mar 2, 2011 | 10:35 PM
JayplaySS2's Avatar
JayplaySS2
That's a baby cam (IMHO). If I were looking for a tame cam, I'd go with Spin's 230/234 at the very least.
I'll be going 238/242 myself-
Old Mar 3, 2011 | 09:08 AM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
- Vararam Intake
382 RWHP
Thanks!
That sounds like a nice cam to me.
Old Mar 3, 2011 | 09:28 AM
KOTYKB's Avatar
KOTYKB
I want a mild cam that will give me the HP boost I'm looking for but it has to be reliable. Hopefully this cam will have the distinctive sound at idle?!?
Old Mar 3, 2011 | 09:38 AM
old motorhead's Avatar
old motorhead
There's a huge difference in the two cams you're considering. First will be mild with good manners. Second will have a rough idle and have more drivability issues. Sure, it will make more hp, but at a cost. Some will tell you they can tune that second one to drive like stock. That hasn't been my experience with a similar cam. Fun for a while, but gets old quick.
Edit....whoops....what happened to the 231/234 112lsa cam? Looks like you edited it out? That's what I was referring to.
Old Mar 3, 2011 | 09:53 AM
JayplaySS2's Avatar
JayplaySS2
Yes, you will notice the cam at idle.
I like the 231/234 (of those 2 choices)
Old Mar 3, 2011 | 10:48 AM
Ragtop 99's Avatar
Ragtop 99
You've mentioned reliability twice. Big overlap cams can be just as reliable as low overlap cams, they just can have downsides in terms of low rpm driviability and fuel consumption. Focus on drivability and power curve to decide your specs. To increase reliability, select cam lobes without massive lift and run a good spring.
Old Mar 3, 2011 | 11:22 AM
KOTYKB's Avatar
KOTYKB
I was looking the 231/234 112lsa CAM until I read further and it says "Ready to race? Our lineup of max-effort power cams is a great choice for stock cubic inch combinations. These cams will require gears, converter, and tuning, If you need assistance with cam selection, please contact our sales department."
I'm not looking to upgrade Gears or Converters...
Either way do I need a high volume oil pump with a mild cam?!?
Old Mar 3, 2011 | 11:40 AM
old motorhead
Your stock pump will do fine.
Old Mar 3, 2011 | 05:19 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
I went with a 235/239 Comp cam on a 112 +4
just received a video with the first start-up after install (maybe 15 minutes ago)
Old Mar 3, 2011 | 08:13 PM
KOTYKB's Avatar
KOTYKB
With a "TR TRuTorq" Level 2 - 223/230 .609/.604 115 LSA cam will I be able to drive in 6th on the freeway going roughly 65-75 MPH and not have issues with it surging etc?
Old Mar 3, 2011 | 09:32 PM
old motorhead
You shouldn't. I have a very similar cam in my LS3 (little less on the intake, more on the exhaust, same LSA). The idle is a little rough sounding, but it will pull smoothly from idle on up.
Old Mar 4, 2011 | 12:07 PM
KOTYKB's Avatar
KOTYKB
It looks like I'll be installing a cam and differential brace once all the snow melts in Minnesota
To CAM Selection for my LS2
