2005 Differential Brace
Old Mar 4, 2011 | 10:02 AM
KOTYKB's Avatar
KOTYKB
Default 2005 Differential Brace
I plan in installing a cam in my 2005 Z51 with a LS2 and 6-Speed this spring. After researching around Corvette Forums I’m disappointed to learn that my differential is fairly weak. I plan on running ~460 rwhp and I didn’t budget to buy a new differential this summer. I’ve been looking around through the forums to find a good differential brace since it prolongs the life of the differential. Are there any vendors that have them available? Also am I correct to state that it prolongs the life of the differential and if it does break it saves the transmission?
Old Mar 4, 2011 | 10:13 AM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
Doug from ECS just posted recently that they offer the 05 A4 brace.
http://forums.corvetteforum.com/1576930304-post8.html
Old Mar 4, 2011 | 10:20 AM
KOTYKB's Avatar
KOTYKB
I found out that East Coast Superchargers has them for $399. Are there any DIY instructions on how to install the differential brace? It sounds like I need to drop the rear cradle to do this which seems daunting.
Old Mar 4, 2011 | 10:39 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Thanks for linking RPM!
You do not need to drop the cradle to install the brace, the exhaust will need to be removed to get up there though. It is naturally easier when everything is down, but we most often install them with everything in the car.
Instructions come with the product.
Old Mar 4, 2011 | 10:43 AM
KOTYKB's Avatar
KOTYKB
Excellent! I talked to Doug at East Coast Superchargers and he recommended their own differential brace but is that the same as the one you're referring to? Do you have a link to the brace on your website?
I assume you're referring to the one at the top of the page.
http://www.eastcoastsupercharging.co...rut_Brace.html
Brian
Old Mar 4, 2011 | 11:36 AM
360jeepboy's Avatar
360jeepboy
What does it do to make the diff stronger?
Old Mar 4, 2011 | 11:38 AM
KOTYKB's Avatar
KOTYKB
It has four bars that brace the transmission and differential
Old Mar 4, 2011 | 11:48 AM
360jeepboy's Avatar
360jeepboy
But does it solve the weak diff problem? I was told it didn't.
Old Mar 4, 2011 | 11:51 AM
KOTYKB's Avatar
KOTYKB
It strengthens the differential and if it does blow it should save your transmission which will save you $$$
Old Mar 4, 2011 | 07:15 PM
Joe_Knesek's Avatar
Joe_Knesek
When I picked up my car from LG Motorsports I asked about adding a brace & was told it would be a waste of money. My 05 produces more than 460 RWHP & has held up just fine without a brace.
Old Mar 5, 2011 | 02:13 AM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Brian
I bet it's the same one since that is Doug at ECS that you are talking to here also.
Old Mar 6, 2011 | 08:09 PM
debo's Avatar
debo
Jumping on board for info....
Old Mar 6, 2011 | 09:14 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I have an older design (not ecs) two bar brace and it did not save my trans mainshaft when my diff case cracked and blew to pieces.
I would buy a four bar brace. If it works it could save you a $2000+ trans rebuild.
I don't know if it can save the mainshaft on a break like this....though my mainshaft wasn't bent much, but enough to replace. Maybe this 4 bar brace could have saved the trans mainshaft?
My friend just stripped his ring gear in his 05 and the case cracked but didn't break...he did not bend his mainshaft. He had no brace. But that is unusual, most of the time they bend.
To 2005 Differential Brace
