Question...steering wheel too loose???
Old Mar 5, 2011 | 12:18 PM
YUH8N4's Avatar
YUH8N4
Default Question...steering wheel too loose???
Guys,
Maybe you can help me out. When driving at high speed on the highway,the steering wheel is not as tight as i would like. Is there something I can do or buy to make the steering wheel tighter while driving???
Thanks,
Sean
Old Mar 5, 2011 | 12:28 PM
RicK T's Avatar
RicK T
Are you saying the "steering wheel on the steering column" is loose?
OR
The "steering feel" on the road is too loose/light?
Old Mar 5, 2011 | 12:39 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
If your car feels like it's drifting a little from side to side and you have more than a fraction of steering wheel movement to compensate then that could be inner tie rod wear on the steering rack.
Kenny94945's Avatar
Kenny94945
Actual loose or feel?
Feel No. With one exception to put/flush new power steering fluid. Could also check (lower) tire pressure
Loose. Tie rods, bad rack, wheel bearings etc......
Old Mar 5, 2011 | 02:41 PM
YUH8N4's Avatar
YUH8N4
The steering feel. I thought there was something i can change to tighten the steering wheel so when i go fast there would be no movement.
To Question...steering wheel too loose???
