Any Supercharged 402s out there?
I'm curious what your #s look like, if you've got a dyno sheet feel free to post it up and also I'd like to know the compression ratio you went with.
In his profile there's a link to his build information, says CR is 10:1. He's got quite an extensive list of mods lol
http://forums.corvetteforum.com/c6-c...2-stroker.html
I don't see any dyno.. but he did post some info on it. 9.1 or 9.2:1 , 657rwhp/590tq.
Displacement - 402 Stroker
Compression Ratio - 9.1/2.1
Heads - 225 CC AFR
Valves - 2.08
Rocker Arms - 236 Comp Pro
Pistons - Diamond
Crankshaft -Calis
Rods - Pro Rods
Intake Manifold - Fast Intake
Throttle Body - Air Flow Tech
Fuel Injectors - 60lb. Inj. Siemens
Fuel Pump - Bosch/w Booster Pump/ Custom Fuel Rails
Ignition - Stock
Exhaust Systems - BPP Headers and Corsa Mufflers
Transmission - Upgraded Stock
Clutch - Twin Disc Clutch System (Zoom)
Front Suspension - GMT 1-Sway Bars
Rear Suspension - Stock
Rear End - Stock
Front Brakes - Willwood Big Brake (Six Piston Brake Pad)
Front Wheels - Asantis (Black, Chrome, 19 x 9.5)
Rear Wheels - 20 x 12.5
Front Tires - Perrelis 285s 30 19s
Rear Tires - Perrelis 345s 2520s
Additional Road Coarse Rims and Tires Included
Oil Coolers - B&M
Pro Charger SuperCharger delivering 8lbs. of boost
ZO6 Wide Body Conversion/w Rollbars
Under 14.000 miles total: 2,100 with new motor
Unbelievable Add ons such as:
Vertical Doors, Carbon fiber panels and hood, Carbon Fiber interior, Navigation System, Sparco Race Seat, 5 Point Seatbelt Harness and much more. Over $100,000 invested.
Dynojet Evaluation sets car at 657RWHP with a 590lbs of torque, tuning performed by Jeromy Fernato.
