Crank pully wobble
Old Mar 10, 2011 | 12:17 PM
themotoking's Avatar
themotoking
Default Crank pully wobble
I have read its common on 05 years where the bolt starts to loosen up. I have a slight wobble right now. I am going to be getting it fixed in a month or two with new pully, new bolt and friction washer. I can't help but think am I going to do any damage or put more wear on the motor with it like that? It is only a mild wobble but will this put more pressure on the crank and cause bearing wear or am I safe to drive the car unless the wobble gets worse?
Old Mar 10, 2011 | 12:31 PM
MARSC6's Avatar
MARSC6
If its coming loose tighten it immediately.
What happens is the pulley comes loose then starts slipping which will damage the end of the crank. If the shaft gets damaged its to late for a new pulley and bolt.
Old Mar 10, 2011 | 12:39 PM
Walt White Coupe's Avatar
Walt White Coupe
Slight pulley wobble is NORMAL. If you don't have an early 05 then bolt loosening is NOT a problem you should be NOT be concerned about it. If your belt is not chirping, NO ACTION IS REQUIRED. A pulley that is wobbling enough to cause chirping and needs replacement will NOT hurt the engine.
Old Mar 10, 2011 | 02:31 PM
Blue Devil 08's Avatar
Blue Devil 08
Pulley wobble slightly is normal on a LS motor !!!!!
Old Mar 10, 2011 | 04:23 PM
themotoking
I am a bit confused by some of the responses. I DO have a 05 not sure if it's "early" or not. It is also a Z51. There is a slight wobble and chirp and if you watch the tensioner it bobbs up and down due to the crank pully. It's not loose as in the bolt coming out but I predict it's loose because the 05 had this problem and there was a service bulletin on it that is suppose to be why it gets the wobble. According to the shop and my estimates you need to take the whole front end of the car apart to change the pully or gain access to the bolt unless there is a special tool. I can get a socket on it but there is absolutely no room if it is connected to a ratchet.
Old Mar 10, 2011 | 04:40 PM
richgoat's Avatar
richgoat
Do yourself a favor, take it to a reputable shop and have the crank pinned. Should be about $500 or less, and you won't have to worry about it. Also, if you look in the FAQ only certain early 05s were affected up to a certain VIN #. However, I have one of the last 05s that was not affected, and I had a wobble (more than normal I believe). I also believe that is the reason my water pump took a crap at 16k miles, and why my alternator bearing decided to whine louder than a blower, at 30k miles or so.
So, to be on the safe side and save yourself money, get it pinned ASAP. Should be about 3-4 hours of labor, a NEW bolt, and a pin kit. A wobbly pulley will throw everything out of whack if not straight, as it did to my water pump and alternator.
Old Mar 10, 2011 | 04:43 PM
Walt White Coupe
The "loose bolt" in 05's was "suspected" in the first 11039 cars. Your VINs last 5 numbers tells you if you are in the affected range. You are right the GM procedure calls for a lot of front end disassembly to replace it and it's about a $1000 job. Others have said it can be done without all the disassembly and cheaper. If the belt is chirping, the only cure is to replace the crank pulley (harmonic balancer). A wobble can occur with a loose bolt but once the bolt is actually loose it's a short trip to the pulley flying off. More likely it's a failed rubber flexible coupling in the crank pulley that is causing the pulley to wobble and the belt to chirp.
Old Mar 10, 2011 | 04:51 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Mine was replaced at a local performance shop for $150
Old Mar 10, 2011 | 06:52 PM
Gering's Avatar
Gering
Tolero Apto Victum
I had the wobblies on my 07, took it to Corvettes of Houston and had it replaced with one from ATI http://www.atiracing.com/products/da...ts/damserp.htm
Good Luck!
Old Mar 10, 2011 | 09:02 PM
themotoking
How is that possible? Do they have some type of magic trick where they can pull it off even though the front steering rack is blocking it in? Thats amazing! My local dealer also says it's $1000 labor because you have to remove steering rack and other things. If there is some magic trick im sure everyone wants to know how it is done
Old Mar 10, 2011 | 10:12 PM
richgoat's Avatar
richgoat
Thing is they will more than likely not pin it, and knowing dealers they will just tighten it up.
Not sure where you are located but if you are out of warranty, I recommend you find a trustworthy mechanic/shop to work on your car. Luckily for me, ecs is only 25mins away and they are the only ones who I let work on my car.
Old Mar 10, 2011 | 10:53 PM
Ursoboostd's Avatar
Ursoboostd
i have an 06 and had the pulley wobble. Had an ATI installed.
Old Mar 31, 2011 | 04:09 PM
Larell's Avatar
Larell
I have the wobble on my 07. Is this sort of thing covered by the 07 and up power train warranty? I am within the 5yr/100k mile limits of the powertrain warranty they offered starting that year.
Old May 14, 2012 | 06:03 PM
Gromit3860's Avatar
Gromit3860
Default C6 Crank Pulley
I have a 2011 Grand Sport and the pulley is moving enough to make the belt chirp. it is visibly wiggling. Being under warranty is a good thing, but I hope the shop can accomplish whatever repairs are necessary without taking half the summer!
By the way on my LS3 the pulley bolt head is 15/16, but it's impossible to get both the socket and handle in there.
Old May 14, 2012 | 06:29 PM
debo's Avatar
debo
Parts are being ordered now to replace my balancer, if this happens again I'm going with the ATI unit.
Old May 15, 2012 | 02:56 AM
EVRose's Avatar
EVRose
Mine is getting replaced too on Wednesday. 47k miles I would think if the bolt were loose it would have come off a long time ago and my vin is below the break #.
Old May 15, 2012 | 12:08 PM
m R g S r's Avatar
m R g S r
No it's a sign of a defective part made by GM. The wobble will transmit vibrations through the crankshaft at high RPM and could potentially do damage to the bearings / motor.
I put on a brand new OEM pulley to fix the wobbling, it was dead straight. No runout at all. Then within a month the replacement failed as well.
I switched to an expensive ATI harmonic balancer and it has been perfect for almost a year now. And I'll never have to worry about it again.
Get rid of that OEM piece of junk !
Old May 15, 2012 | 12:33 PM
Walt White Coupe
Baloney
Old May 16, 2012 | 07:43 AM
qwik150's Avatar
qwik150
Baloney
Seems we have a GM tech/Service dept manager here ... Balancer wobble is not normal and is only acceptable because GM proclaims it is because of a poorly designed part . I have yet to see an aftermarket balancer/pully wobble . It is a common PROBLEM on LSx motors but in no way is it normal , unless you say its normal for these to suffer from this issue.
To Crank pully wobble
