Gas smell
Old Mar 11, 2011 | 08:07 AM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Default Gas smell
With a weather break I took the Car out for a drive. I know it was sitting for a bit before I went out. I noticed a considerable Gas smell. I drove it a few miles and it was still there. I gave it a look see as I thought I had a
injector leak but all appeared ok around the Engine Bay. It was running
perfectly before but now I don't know what to think ?
Old Mar 11, 2011 | 08:26 PM
CPG1962's Avatar
CPG1962
St. Jude Donor '09-'10
Change your cabin filter. It will do the trick.
Old Mar 11, 2011 | 08:28 PM
Red06Vette's Avatar
Red06Vette
Had the same problem with mine, found the cabin filter door was partially open
Old Mar 11, 2011 | 09:11 PM
LEAVINU's Avatar
LEAVINU
Mine has actually blown off before and landed on top of the battery.
Old Mar 12, 2011 | 07:06 AM
LSCHLEM's Avatar
LSCHLEM
Default CF guys are the best
You are right. I found it laying on top of the Battery. I didn't even know it was there. Thanks guys. Leon
Old Mar 12, 2011 | 07:42 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
any ideas on how it blows off? that sounds strange because it doesn't seem like it has a lot of pressure on it, but I could be wrong.
Old Mar 13, 2011 | 11:56 AM
LEAVINU's Avatar
LEAVINU
Def not pressure inside blowing it out from what I can tell. Think it has more to do with underhood pressure and airflow. Mine generally blows off after some serious speed like at the Miami Mile.
To Gas smell
