Old Feb 19, 2015, 07:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
Print Wikipost
Window Regulator Replacement Help
Old Mar 11, 2011 | 02:41 PM
tsjolly's Avatar
tsjolly
Default Window Regulator Replacement Help
2005 Z51 Corvette
Bought a used drivers side window regulator off of ebay (also a forum member and thanks by the way). My mechanic was recently let go and now I have to undertake the install.
Any links to replacement instructions would be helpful.
Thanks in advance.
Old Mar 11, 2011 | 02:56 PM
RPHCRMZ51's Avatar
RPHCRMZ51
Search is your friend:
http://forums.corvetteforum.com/c5-t...wr-window.html
Make sure you clean the contacts and that are all aligned properly before installing. Make sure they install tight. Giood Luck
Old Oct 25, 2011 | 10:06 AM
LMBullet's Avatar
LMBullet
I know I'm bumping an old thread but a lot of times when you google a question these threads come up with the only response being "search is your friend"
To Window Regulator Replacement Help
