Oil Pressure - Question
At idle when its warm i saw it all the way down to 22psi. Starts around 40 when cold then once its warm and i am crusing on the highway it is below 30psi. Seems low to me.
I have an LS2 and had to rebuild the motor which is now a 403ci and the guy who did it, was going to modify a stock oil pump to increase the spring pressure and flow a bit to help with the Road Racing.
I wondered what other people run for typical cold start (and ambient start temperature, maybe like garage temp & psi) and also hot running. I have a 160* thermostat so my oil typically runs about 196-199* when i am cruising on the highway.
I just am trying to keep tabs on my new engine and see how it is running after i have taken it to the race track twice.
Any other things i should watch with a new engine as well.
Coolant maxed out at 203* while i was running really hard at the race track but the oil got up to 270* when it was 70* outside, that worrys me what it would be like with 100+* texas summers.
I would like to still enjoy the car, but don't wanna burn it up.
Do you have an oil cooler? ie Z51 option.
What is the pressure at 4500 & higher RPM?
On the track the oil got up to 270* for the highest point, but i know there was a point where I had to come into the hot pit and when i was resting and it was hot i saw 9psi, that scared me, but it was under idle so not running hard then.
While running hard my oil pressure didn't get that high either, at race temps it was down to ~20psi maybe 19-22 during some turns, but not that much higher even when going straight under full throttle. Maybe 30psi max, no 50s or anything even at high RPMs.
I wouldn't doubt a thicker weight might keep things a bit more in check, and an Accusump would be a good idea for the hard turns as i keep pushing things harder and running with better tires. Right now its just R888s but i would be afraid to run Hoosiers.
AMSOIL SAE Synthetic Premium Protection 10w40 (Product Code AMOQT)
This oil has a higher viscosity which it looks like your engine needs, and it has high levels of anti-wear additives (zinc – 1378 ppm, phosphorus 1265 ppm). I used this oil in my 02 Z06 for several seasons before AMSOIL came out with a true racing oil.
I'm more than happy to ensure forum members can get AMSOIL at dealer wholesale, about 25% below retail, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
