A/C question
Old Mar 18, 2011 | 05:51 PM
thaitime's Avatar
thaitime
Default A/C question
My 99 dual A/C was working great until one day not long ago I heard a hissing sounds well it turns out it was the valve on the low pressure side was leaking so I took it in today to have the valve replaced and a leak down done and also recharge the system well after driving home I noticed the same symptoms as before cold on passenger side but just warm on drivers side, I can switch the A/C to defrost and it blows cold on passenger side but still warm on drivers side even through the defroster also I don't hear the clucking noise that some talk about with the broken gear syndrome on the actuators, also I am not sure how to check for codes or what to do if I was to find them.
any help would be appreciated
thanks inn advance
Old Mar 18, 2011 | 06:24 PM
RicK T's Avatar
RicK T
Wrong Forum, you should ask in the C5 General Forum.
FWIW, my guess is, it is a bad actuator with a torn/shredded curtain. I'm sure the C5 guys will help you. Good luck.
Old Mar 18, 2011 | 06:25 PM
thaitime's Avatar
thaitime
Thank you I'll change it over to C5 my mistake and thanks for the advice.
To A/C question
