Removing Fuel line
Old Mar 18, 2011 | 07:54 PM
valleygrandsportc6's Avatar
valleygrandsportc6
Default Removing Fuel line
Hope this is the correct place to post this.
I am trying to remove the fuel line that goes through the Fuel rail cover on an LS3. I got the correct tool to do the removal and followed what little instructions there were in using it.
I removed the safety catch first - then the tool slides in into the inner Fuel connector line OK and I feel it pressing on the internal decompression ring - but I cannot get the connector to pop off. I figured it was supposed to slide off after inserting the tool. I have tried pushing forward and then pulling backwards - but it seems very stuck on there. Any tips or tricks on how to remove this. The car has not been run for a day so their should not be any pressure in the line.
Sorry in advance for the noob question.
Old Mar 18, 2011 | 07:56 PM
RicK T's Avatar
RicK T
I've never done it but here's a DIY I saved for reference, hope it helps:
http://forums.corvetteforum.com/c6-c...fuel-line.html
Old Mar 18, 2011 | 11:17 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Whatever you do, don't force it.
It takes some fiddling to get the fitting to release. Make sure you are using the correct size tool. They come in various sizes. Use the largest one that will fit inside the connector. I make one from an old sprinkler PVC elbow, but that's another story.
There are 4 spring catches located inside the fitting. All 4 have to retract using the tool before the connector will separate. Pull and push with the tool firmly inserted and it should eventually pop free.
Old Mar 18, 2011 | 11:53 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
You need to bleed the pressure off of the fuel system using the Schrader valve on the driver side of the fuel rail. Even if you haven't driven it for several days, there will still be pressure.
Old Mar 19, 2011 | 01:21 AM
valleygrandsportc6
Thanks everyone - I really appreciate the advice.
Old Mar 19, 2011 | 12:41 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Why are you trying to take it off?
If you want to remove the fuel rail cover, you can just split the part line, one part up, one part down, turn it 90° and remove it. There's a bit of a trick to it but you'll get it. If you're worried about scratching it, put some blue tape on the fuel line.
Old Mar 19, 2011 | 02:43 PM
valleygrandsportc6
Install custom painted FRC's. Did not want to risk scratching them.
Old Mar 19, 2011 | 03:14 PM
j_digi454's Avatar
j_digi454
Trust me, you will scratch them no matter how careful you are even using tape to protect them. Removing the fuel line is the best approach for painted FRC's. I learned the hard way and now remove the fuel line.
To Removing Fuel line
