LS3 oil pressure
Old Mar 28, 2011 | 08:48 PM
sammy burks's Avatar
sammy burks
Active Streak: 90 Days
Default LS3 oil pressure
What is the normal oil pressure on the LS3 THANKS
Old Mar 28, 2011 | 09:29 PM
rbrcs's Avatar
rbrcs
Disabled by request 27 March 2026
I have a 08 coupe and it runs around 40.
Old Mar 28, 2011 | 10:11 PM
AtomicLS3's Avatar
AtomicLS3
Depends on the engine rpm. Normal cruising is around 40.
Old Mar 29, 2011 | 12:17 AM
Mike's LS3's Avatar
Mike's LS3
I have an 08 and 40 psi is normal at cruising.
Old Mar 29, 2011 | 05:23 AM
BSSN's Avatar
BSSN
at idle, warm temp?
Old Mar 29, 2011 | 09:31 AM
haljensen's Avatar
haljensen
28-30 PSI hot idle.
Old Oct 18, 2013 | 05:33 PM
AFflyer's Avatar
AFflyer
Would 55 psi be high while driving a curvy road but not aggressively driving? My car smells like its burning oil but all indications are that its operating normally. Oil is not low and all temps are OK.
Old Oct 19, 2013 | 11:37 PM
Thunder8's Avatar
Thunder8
Originally Posted by haljensen
28-30 PSI hot idle.
That's exactly what mine runs using: M1 5W-30 with almost 50K on the clock and fully warmed up, even in 100* weather...I live in AZ.
The other person didn't say any of the particulars, but I think they do make some difference.
Old Oct 21, 2013 | 07:13 AM
Seadawg's Avatar
Seadawg
Depends on if the engine is a dry sump, like on some of the Grand Sports. When cold, mine pegs the needle at 80+ psi, then runs about 50 - 60 psi crusing when when warmed up. The wet sumps will run much lower.
Old Oct 21, 2013 | 10:31 AM
Gabbiani's Avatar
Gabbiani
Wet sump ls3 is pretty low compared to previous Chevy engines. A hair under 30 at hot idle is pretty normal. I have seen some cars get down in the teens on a road course with crazy oil temps.
To LS3 oil pressure
