nitto 555R
Old Mar 29, 2011 | 05:31 PM
youout's Avatar
youout
Default nitto 555R
I have a 2007 C6 with A6 and it is tuned and setup running Michelin PS2’s that have a 26.9 inch diameter ( 285/35ZR/19). I want to use Nitto 275/40ZR 18 inch 555R tires for use at weekend visits to local drag strip. The 18 inch Nitto tires have a 26.89 diameter.
I want to avoid having to go in and reset the computer for a different tires so I am interested in the 18 inch instead of going 17 inch. Given these diameters are almost the same will this work on the car without screwing up the shift points?
I have to use these tires to drive to the strip which is about 60 miles away so the choice is 555R.
Does anyone have any actual experience using these tires on a C6 with an A6?
Old Mar 29, 2011 | 06:08 PM
LS1LT1's Avatar
LS1LT1
That set up should be just fine at your level...there's a guy I race with named 'jpee' (he posts in this section from time to time as well) that has a 2005 A4 C6 LS2 with a Vararam, thermostat and tuning and he hooks well on 305-35-18 Nitto 555Rs.
Your shift points and even ABS/TC/AH should all be fine as well as long as long as you still have the stock TPMS (tire pressure sensors) in the new wheels.
That's a safe way to look at it but just for the record, plenty of us drive A LOT further than that on other supposedly 'less streetworthy' drag radials (M/T, Hoosier, BFG etc.) and it works out just fine. I've even seen some driving to/from the track on bias ply/DOT slicks and pulling it off without issue as well.
Old Mar 29, 2011 | 08:20 PM
youout's Avatar
youout
Default low speed rallye
glad to hear that. i have considered the Nitto NT05R as an otion. my concern is that the NT05R may not meet my need for low speed coursing. our club gets involved in those events and i want to have rear tires to use for both type of uses instead of the PS2's. they are too expensive to wear out.
is anybody using NT05R tires for low speed events
ps, i will be using the correct tpms.
Old Mar 29, 2011 | 08:21 PM
jpee's Avatar
jpee
"YES" I use 305/35x18" Nitto 555 .. I have a stock converter and my 60' are 1.860 - 1.900 I never have traction problems, or get ANY codes on my DIC...
In fact I do not have any air pressure sensors on the rear 18" wheels, and I drive app 100 miles to the track.. about 1/2 way there I'll get a DIC message telling me my Air Pressure Sensors are not working.. I just rest the DIC, and have no problems using the above set up...
I have no problem ...I've even hit rain and was OK but kept my speed to 45-50 mph... and change the tires when I hit the wear bars... or SOON after..
Old Mar 29, 2011 | 09:26 PM
LS1LT1's Avatar
LS1LT1
I have a set (285-40-18s) in the garage that I haven't mounted yet, they might even become my basic daily driver/cruising tires for the C6.
Old Mar 29, 2011 | 11:34 PM
res0n0xg's Avatar
res0n0xg
I have a good question, I can't find tons of answers on.... what wheels are you guys running for daily drivers that are 18"???
Old Mar 30, 2011 | 01:24 AM
LS1LT1's Avatar
LS1LT1
I use various factory C5 (wheels in both 17" and 18"), I have at least two of EVERY single style they made between 1997 and 2004 LOL.
Old Mar 30, 2011 | 06:01 AM
youout's Avatar
youout
Default tire sise
so for the Nitto NT 555R - 275/40ZR /18 the 18 x 9.5 is the right C-5 rim to use? Nitto recommends a minimum of 9.5 width.
I can find a 18 x 10.5 also and thought that might give me more optinos for tire width in the future. The 18 x 10.5 is a +58 mm offset. please confirm that this size works in a stock C6 body style.
Old Mar 30, 2011 | 11:01 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Coincidentally, as they are currently on sale, I just asked my shop Horsepower Sales about these NT05R's today, and they told me they have many high horsepower customers using them with great success. I think mostly for street duty in these blown cars.
I have a question in whether anyone is using them on the drag strip and what their results are.
Old Mar 30, 2011 | 11:15 AM
LS1LT1's Avatar
LS1LT1
Yes, that 18x9.5 should be perfect for those 275s.
As for 10.5 wide, they might be a little wide for 275s but will allow you to use wider tires in the future if need be.
18x10.5 on a 58mm offset (which is the stock/OEM size of rear C5 Z06 rims) will fit on a base C6 but they won't sit exactly right in the wheel wells, at least not as well as the base C5 18s (18x9.5 on a 65mm offset) will.
I'm an automatic making less than 400rwhp of course but will eventually be testing them there as well.
Old Mar 30, 2011 | 11:19 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I will second the confirmation that the base C5 18" wheels with 305's fit very nicely on the C6, they are about perfect. I would think the wider ones would stick out.
Old Mar 30, 2011 | 07:16 PM
youout's Avatar
youout
Default 65 mm
I have been searching for 18x9.5 with a +65mm offset. all i can find are +56mm offset. where can you find 18x9.5 with a +65mm offset?
Also I have looked at what offset is and do not see how a lower offset will cause any problems with the body. Any thoughts on this?
Old Mar 30, 2011 | 07:39 PM
JoesC5's Avatar
JoesC5
I believe that the base OEM cast aluminum C5 18X9.5 rear wheel has a 65mm offset.
Mike Campbell's Avatar
Mike Campbell
I had 555's on my C5. When I replace the stock GY on m C6, I'm thinkin about going with 555's. However, do the make a 19" for the rear??
Old Mar 30, 2011 | 08:56 PM
LS1LT1's Avatar
LS1LT1
Yes, the standard C5 LS1 rear 18" rims are 65mm...just seek out a 'stock rear C5 size' aftermarket wheel (or simply, an actual rear C5 LS1 wheel LOL ) and you'll be fine.
Unfortunately no, only their newer NT-05R comes in a 19" and that's a big 345-30-19.
Old Mar 31, 2011 | 12:33 AM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Why not use the NT05? It is a road course tire and is the same compound as the 555R. Both the 555R and NT05R are drag radials and will have that "sloppy" rear end feel. Also, according to the Nitto website the NT05 is rated better in dry performance than the 555R
Old Mar 31, 2011 | 05:51 AM
youout's Avatar
youout
the NT05R are still on the table but part of the reason for going with 555R is diameter. The NT05R diameter for a similar size tire 285/40DR 18 is 27.09. I know this is very close to the 26.90 on the PS2 and might be just fine. I just want to swith to the DR tires on the weekend and back to PS2 on monday. do you know if shift points remain the same using the slightly larger diamter?
i just want to be very sure of this before I spend the money. where i live there are not many I can talk to about this type of change to the car.
To nitto 555R
