Throwing code P0355
Old Mar 29, 2011 | 08:41 PM
gibear2k5's Avatar
gibear2k5
Default Throwing code P0355
Well last week I brought the car out of hibernation and had a check engine light. After a scan it returned a code of P0355, I cleared and drove around a bit and it did not return. Today I brought it out, drove about 20 miles with no issues. Shopped with the wife a little; during the trip home the engine light illuminated again, same P0355...
Supercharged LS3 with 7K miles...
Is this going to be expensive?
Old Mar 29, 2011 | 08:59 PM
RicK T's Avatar
RicK T
P0355= Ignition Coil Primary circuit malfunction.
No idea, haven't seen that before.
Old Mar 30, 2011 | 04:31 AM
Tag_sk's Avatar
Tag_sk
According to the service manual P0355 is Ignition Coil 5 control circuit.
Conditions to set DTC: ECM detects the IC circuit is grounded, open, or shorted to voltage for less then 1 second. Possible causes; wiring to coil, ecm or the ignition coil. Make sure the connector is securely connected.
To Throwing code P0355
