Active Handling questions
Old Mar 30, 2011 | 08:55 AM
Harbinz51's Avatar
Harbinz51
Default Active Handling questions
If I run equal tire diameter front to rear will I have problems with Active Handling?
Old Mar 30, 2011 | 08:59 AM
FloydSummerOf68's Avatar
FloydSummerOf68
I have never had a problem with active handling running tires shorter, the same height or taller
Old Mar 30, 2011 | 09:02 AM
Harbinz51's Avatar
Harbinz51
Ive heard both ways. I am either going to mount today or order different tires based on the opinions I get here. Thanks for the input
Old Mar 30, 2011 | 09:44 AM
FloydSummerOf68
Most people who say you will have problems are only speculating and haven't actually done it.
Old Mar 30, 2011 | 09:46 AM
iDoLiZeDbyALL's Avatar
iDoLiZeDbyALL
I had a similar question. Will 20x8.5F and 20x10R affect anything major? Tire rub, speedo, bottoming out on the fender wheel on bumps...etc.
Old Mar 30, 2011 | 09:48 AM
Harbinz51's Avatar
Harbinz51
Tire size is the real key to answering your questions. 20s will fit with the correct offset and tire size
Old Mar 30, 2011 | 10:48 AM
iDoLiZeDbyALL
I thought so. Just making sure. Guess I would need 30 or 35 series on the front. Could do 35s all the way around.
To Active Handling questions
