Diff Fluid and Tranny Fluid Change!!
Old Mar 31, 2011 | 08:20 PM
singhsupercharged's Avatar
singhsupercharged
Default Diff Fluid and Tranny Fluid Change!!
What Kind of differential fluid and tranny fluid i should use on my 2005 C6 with a blower Z51 pack.. I may be taking it to the track may be 5 times a year..Just bought a pair of slicks...But other than that it will be my weekend driver..
I asked a few places everybody had given different opinions..
I bought some royal purple with limited slip additive already in it.. But somebody recommended use more additive would be smart sometimes its not enough..
For the tranny i was going to go with Synthetic ATF from Mobile 1..
Somebody also recommended AMSOIL..
What should i use for what?
Please advice what would be the best way to go on it..
Old Mar 31, 2011 | 08:32 PM
timd38's Avatar
timd38
Lots of brands, lots of opinions.
I use RedLine and if you get to Milwaukee, you can drive my car and see the difference it made in the way it shifts.
But like said, lots of brands, lots of opinions.
Old Mar 31, 2011 | 09:30 PM
singhsupercharged
Hows redline compare to Mobil 1 ATF Fully Synthetic? But what about the rear diff any opinion on that?
Old Mar 31, 2011 | 11:04 PM
Bandit1's Avatar
Bandit1
I'd recommend AMSOIL.
Synthetic Multi-Vehicle Automatic Transmission Fluid (ATFQT)
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
Talk to 'Subdriver' and he can set you up.
Old Apr 1, 2011 | 04:54 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Talk to 'Subdriver' and he can set up.
Thanks for the mention.
These are the fluids AMSOIL recommends for your C6 manual and diff (which are the exact same fluids I use in my C5 Z06 track day car):
Tranny: AMSOIL Torque-Drive Synthetic Transmission Fluid (Product Code ATD1G) (Dexron III labeled fluid)
Diff: AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT)
AMSOIL Slip-Lock Differential Additive (Product Code ADATB)
Note: The Severe Gear 75w90 comes with friction modifier already in it and adding extra is not normally needed for the C5, but the C6 diff seems to need extra modifier, thus I recommend a tube of the Slip Lock for the C6.
And for the DIYer:
AMSOIL Hand Pump (Product Code G2039)
I'm more than happy to ensure forum members get AMSOIL products at dealer wholesale, about 25% below retail, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
P.S. For the drag strip, I'd think you really want less additive not more. The additive allows the diff clutch plates to slide smoothly across each other to prevent diff chatter when the two wheels are spinning at different rates, such as in a sharp turn (e.g. driveway, parking lot, etc). But, it also lowers the torque passed to the tire without grip (inside rear unloaded tire in my case at a road track, and in the case of the drag strip, whichever side of the track doesn't have as much grip as the other) - thus your limited slip diff becomes less limited slip. If your car is only a track car, I'd consider not using any modifier. If it is a dual use track/street car, I'd probably add only an ounce or two of the Slip Lock and see it you have diff chatter. FYI, for the C5, the limited slip diff is supposed to pass 75 ft-lb of torque to the tire with grip. I check this in mine by putting the car in neutral, lifting one rear wheel, and with the front tires blocked, put a torque wrench on the axle nut and see what torque I can get before the wheel spins. Should be at least 75 ft-lbs. Lower than that and I'm losing performance out of slow speed corners and thus need a diff rebuild (new clutch plates).
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Apr 1, 2011 | 07:19 AM
GOLD72's Avatar
GOLD72
Very happy AMSOIL "Preferred Customer Program" user myself. AMSOIL used in all 3 vettes plus the CTS Wagon in my care.
Old Apr 1, 2011 | 04:01 PM
singhsupercharged
There are two different type of trans fluids.. Mines a daily driver as may be 5 times a year track days.. Any recommendation for that tranny fluid..
Old Apr 2, 2011 | 10:23 AM
C66 Racing's Avatar
C66 Racing
Recommendation for tranny fluid for dual use daily driver and track day car (same fluid I use in my 02 Z06): AMSOIL Torque-Drive Synthetic Transmission Fluid (Product Code ATD1G)
Old May 11, 2011 | 08:27 PM
Ursoboostd's Avatar
Ursoboostd
Noted for sometime in the near future.
To Diff Fluid and Tranny Fluid Change!!
