2007 c6 z51
Old Apr 2, 2011 | 10:30 AM
dfelsner01's Avatar
dfelsner01
5th Gear
Default 2007 c6 z51
i have 78k on my vette and wanted to know if i should change the transmission fluid and rear axle fluid? i bought the car not long ago and do not know if it's ever been done? also when should i look into changing out the plugs etc...
Old Apr 2, 2011 | 10:37 AM
dfelsner01's Avatar
dfelsner01
5th Gear
correction 68,000 miles
Old Apr 2, 2011 | 11:13 AM
RicK T's Avatar
RicK T
Welcome to the Forum!!!!!!!! Have fun.
Do you have an owner's manual? If yes, the maintenance recommendations start on page 430. If not, here's a link to an online copy:
http://www.gmpartshouse.com/download...07corvette.pdf
Quick answer, under normal use the plugs and auto trans fluid are good for 100,000 miles. Manual trans doesn't need anything but many change the oil anyway whenever they feel like it, it "can" improve feel and performance.
Old Apr 2, 2011 | 11:45 AM
dfelsner01's Avatar
dfelsner01
5th Gear
whould you reccomend changing the rear end fluid? would performance plugs be better then oem spark plugs?
Old Apr 2, 2011 | 12:12 PM
RicK T's Avatar
RicK T
If it ain't broke to mess with it. Diff fluid "can be" an issue with some of these cars. If you aren't having a problem just leave it alone. OEM spark plugs are best for a stock car. Basically just follow the recommendations in the owner's manual, they're there for a reason......unless you have a specific reason to deviate.
Old Apr 2, 2011 | 12:20 PM
RicK T's Avatar
RicK T
Guess I should mention, since you don't know the history of the car's maintenance, generally the brake fluid should be replaced every 2 years (under normal use) and the engine coolant every 5 years with the recommended DexCool. So I suggest if you want to do anything for peace of mind, do those 2 things.
Old Apr 2, 2011 | 12:37 PM
dfelsner01's Avatar
dfelsner01
5th Gear
ok, big help. One more question. I am considering a cold air intake i was told vararam is the best for the money.... your thoughts? do i need to get the car tuned after that install/
Old Apr 2, 2011 | 01:02 PM
RicK T's Avatar
RicK T
No idea, no experience. You might want to start a new thread just asking about the Vararam or other CAI opinions.
Old Apr 2, 2011 | 01:10 PM
dfelsner01's Avatar
dfelsner01
5th Gear
Default coldair intake for LS2
Looking at the vararam coldair intake system for my 07 vette. Any info on coldair intakes and do i need to get the car tuned after install?
To 2007 c6 z51
