axle strength ??
Old Apr 8, 2011 | 11:33 PM
LSOHOLIC's Avatar
LSOHOLIC
Default axle strength ??
Ok.....so I have been digging up all the axle threads I can find. And I'm confused on which axles are stronger ?? C5Z or the C6Z's(post '07) ?? If you do a search in the C6 section they say C5Z's are stronger then if you search the same thing in the C5 section they say C6Z's(post '07).
So could someone please enlighten me on which is the truth and maybe some facts to back it up.
Thanks...
Old Apr 9, 2011 | 10:55 AM
wooden's Avatar
wooden
my experience as been the stock c6 are stronger than the c5z axles, I broke two c5z axles running street tires on the street rolling about 5 mph stabbing the throttle. I have ran stock c6 at the strip with slicks all day with no problems. you could not give me another set of c5z axles. I have sense gone to DSS axles.
Old Apr 9, 2011 | 12:48 PM
timd38's Avatar
timd38
LG has axles that will take more horsepower. You may want to talk to them.
Old Apr 9, 2011 | 05:02 PM
LSOHOLIC's Avatar
LSOHOLIC
The reason for the question is at my power level the pro's say I can run C6Z axles. I called the 3 major axle guys and all three said just puy C6Z axles in. So I came to the C6 section and started roaming around and every thread said they were putting C5Z's in there C6's. I was confused and leery of just being sold something I didn't need.
If it helps it makes 480ish rwhp and 650ish on the spray, she weights 2880 without me. And yes I do practice the Ranger/J-rod/Robz ect.. launches. Meaning the RXT gets plenty of abuse but no big rpm drops, I'm aggresive off the line but I don't drive it like I own a parts store.
Any input is appreciated...thanks
Old Apr 11, 2011 | 11:22 PM
LSOHOLIC's Avatar
LSOHOLIC
Axle info ?? Not looking for aftermarket info, just C5Z compared to C6Z (axle)??
Thanks..........
Old Apr 12, 2011 | 02:52 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Inquiring minds want to know.
Old Apr 12, 2011 | 03:47 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Thanks..........
Just something to consider, but you don't necessarily want the axles to be the strongest component back there.
While I'm sure it's quite possible to find a set that'll withstand pretty much any level of HP/TQ you can throw at it, for me at least I'd rather have my halfshafts be the weak link as it's a lot cheaper to replace a $300 part rather than a differential or transmission, both of which would likely cost you upwards of $3000.
Old Apr 12, 2011 | 08:29 PM
LSOHOLIC's Avatar
LSOHOLIC
And I do agree to some extent about engineering a weak link. But I'm sure the C5Z or the C6Z axles are not that strong. From what I hear, 650rwhp is where the C6Z axle becomes suspect. (totally dependant on your driving style)
Thanks...
To axle strength ??
