Regular Gas vs Super
Old Apr 11, 2011 | 10:42 AM
THSISIT's Avatar
THSISIT
6th Gear
Default Regular Gas vs Super
Would like to hear opinions.
Old Apr 11, 2011 | 11:28 AM
FloydSummerOf68's Avatar
FloydSummerOf68
This has got to be a troll post.
Hopefully no one falls for the bait.
Old Apr 11, 2011 | 11:37 AM
THSISIT's Avatar
THSISIT
6th Gear
Default deapest apologies to Floyd and possibly others
Am new at this, no troll. I am just learning how to navigate this site, for it is surely very vaueable. Please accept my apologies on asking about gasoline, I did find the other area. Thanks
Old Apr 11, 2011 | 01:27 PM
gunterwalker's Avatar
gunterwalker
From: Cape May, NJ; Guntersville, AL; Orange Beach, AL
I use super. You really didn't ask a question. I can't remember if it asks for 91 or 93.
Old Apr 11, 2011 | 03:25 PM
Sparo2's Avatar
Sparo2
I use 91 but my car is far from stock.
Old Apr 11, 2011 | 04:05 PM
Vette_DD's Avatar
Vette_DD
Unfortunately for our "discussion," you haven't defined "super."
I try to do what my owner's manual says.
Here's what my 2006 C6 owner's manual says:
If your vehicle has the 6.0L V8 engine (VIN Code U),
use premium unleaded gasoline with a posted octane
rating of 91 or higher. You may also use regular
unleaded gasoline rated at 87 octane or higher, but
your vehicle’s acceleration may be slightly reduced,
and you may notice a slight audible knocking noise,
commonly referred to as spark knock. If the octane is
less than 87, you may notice a heavy knocking
noise when you drive. If this occurs, use a gasoline
rated at 87 octane or higher as soon as possible.
Otherwise, you might damage your engine. If you are
using gasoline rated at 87 octane or higher and you hear
heavy knocking, your engine needs service.
My opinion is that it's usually best to do what your owner's manual says.
I always used 93 octane gasoline.
Old Apr 11, 2011 | 04:15 PM
calemasters's Avatar
calemasters
I run 91 (R+M)/2 octane and use a Top Tier fuel. I would run 93 octane, but it is not readily available in my area. I did fill up once with 87 octane. I will never do that again. Excessive knock under load. Electronic Spark Timing can only do so much on backing out timing.
Old Apr 11, 2011 | 07:11 PM
gunterwalker
Hmmmmm. I am a full bolt on car and I have said fill it up regular a handful of times and had no ill effects. I have seen where people did get pings but I didn't have any issue and did drive the car hard with the gas in the tank.
Old Apr 11, 2011 | 08:41 PM
VET4LES's Avatar
VET4LES
I also follow the manual and have used 87 since it was new. Six years and 28,000 miles with no pinging or knocking. If I ever do have it I will switch to a higher octane.
Old Apr 11, 2011 | 09:30 PM
da vette guy's Avatar
da vette guy
i don't get it, you save 3 maybe 4 dollars a tankful for less performance?If you are that cheap why drive a Vette...just sayin...?
Old Apr 11, 2011 | 09:35 PM
VET4LES's Avatar
VET4LES
Originally Posted by da vette guy
i don't get it, you save 3 maybe 4 dollars a tankful for less performance?why drive a Vette...just sayin...?
I'm sure I wouldn't know the difference between 400 and 390hp. If I ever want to take it to the drags I will put 92 octane in. I enjoy the Corvette for what it is. The style and driving it are a big thrill for me.
Old Apr 11, 2011 | 09:38 PM
Ragtop 99's Avatar
Ragtop 99
It shouldn't ping or knock if you run 87 all the time. The car has low and high octane tables. Once the car knows it is running 87, it should use the low octane table. You lose out on some power from less timing, but if you don't flog the car, it may not matter to you.
Old Apr 11, 2011 | 11:43 PM
da vette guy
No disrespect meant,i just didn't see the point,plus you probably get better mileage with the higher octane. But As long as you enjoy your car thats the main thing...
Old Apr 11, 2011 | 11:51 PM
JoesC5's Avatar
JoesC5
You should have quoted the complete part about which gasoline is required in a 2006 C6. The 2006 Z06 is also a C6.
"If your vehicle has the 7.0L V8 engine (VIN
Code E), use premium unleaded gasoline with a
posted octane rating of 91 or higher. For best
performance, use premium unleaded gasoline with
a posted octane rating of 93.
In an emergency, you can use regular unleaded
gasoline with an octane rating of 87 or higher. If
87 octane fuel is used, do not perform any
aggressive driving maneuvers such as wide open
throttle applications. You may also hear audible
spark knock during acceleration. Refill your
tank with premium fuel as soon as possible to
avoid damaging your engine. If you are using
gasoline rated at 91 octane or higher and you hear
heavy knocking, your engine needs service."
Old Apr 11, 2011 | 11:56 PM
vette6500's Avatar
vette6500
made a mistake and put in 87 once, had to baby it until i used most and refilled with 91 to return to normal.
Old Apr 12, 2011 | 12:57 AM
Mike V.'s Avatar
Mike V.
Default Performance across the board
Personally, I use 93 period. Only one poster mentioned it but performance w/ respect to acceleration is an absolute fact w/ higher octane, but these motors (as w/ others stating premium fuel only) run more efficiently, thus get better mpg, signicant enough to overcome the dollar savings at the pump. Research this one, it's well documented w/ respect to cars requiring premim fuel. That said, it literally does not make sense to save a couple bucks at the pump only to lose savings in overall mileage due to reduced mpg. Detonation due to low grade fuel has its obvious effects, that alone should dissuade using low octane fuel.
Old Apr 12, 2011 | 06:59 AM
tomiboy's Avatar
tomiboy
To Regular Gas vs Super
Old Apr 12, 2011 | 07:04 AM
KneeDragr's Avatar
KneeDragr
He might have a bunch of carbon built up in his motor. In that case the knock sensor wont work as well.
Old Apr 13, 2011 | 01:42 AM
Gering's Avatar
Gering
Tolero Apto Victum
My 07 Vet loves Shell V-Power! Over 110,000 miles and still running.
Old Apr 13, 2011 | 08:04 AM
TMRoc's Avatar
TMRoc
I know Shell and Chevron are rated as top shelf gas, but is there a list some where of the top ten types of fuel?
