r888 tire pressures
Old Apr 11, 2011 | 11:32 PM
bavortiz's Avatar
bavortiz
Cruising
Default r888 tire pressures
Hello Everyone,
I am running a set of r888's on my c6 for an autocross club and am having a tough time getting the tire pressures correct. I found this forum post a while back on another forum about how the tires perform better at higher pressures than recommended by Toyo:
http://www.nasaforums.com/viewtopic.php?f=45&t=28171
Any advice about this subject would be most appreciated.
Old Apr 12, 2011 | 07:04 AM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
Originally Posted by bavortiz
Hello Everyone,
I had them at 35 cold and they stuck like glue this past weekend.
Old Apr 12, 2011 | 03:49 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
Are you running stock size wheels & tires?
Old Apr 12, 2011 | 07:30 PM
bavortiz's Avatar
bavortiz
Cruising
35 cold - are the shaved down?
Stock wheel sizes all around but the tires are slightly larger than stock
Old Jun 19, 2011 | 09:46 AM
YeeeeeHaw's Avatar
YeeeeeHaw
Anyone use R888 on stock size C6Z wheels, and what size you use for the rear?
R888 don't have the rear size for the Z, the closest they have is 305/30/19 with max rim width 11.5", but the stock rear rim is 12" wide!!!!
To r888 tire pressures
