Zo6 Brake HELP!!!!!!!
Old Apr 13, 2011 | 09:37 PM
PILLAR's Avatar
PILLAR
Default Zo6 Brake HELP!!!!!!!
I am at my wits end. I am sticking a set of z06 brakes on my 06 twin turbo coupe. I put the front on and bleed them. No problem. Then i put the back on and cant get them bleed. I am getting no air out of it at all. Any ideas????
I am fixin to go crazy.....
Thanx
>>>>>>>>>>>>PILLAR
Old Apr 13, 2011 | 09:45 PM
Swiftrider08's Avatar
Swiftrider08
You said you are not get any air out of them, but are you getting any fluid out of the rears? Be sure to also bleed thru BOTH bleed screws. I did bottoms first and then top.
Old Apr 13, 2011 | 09:50 PM
PILLAR's Avatar
PILLAR
Sorry Im not getting anything out of them.
Old Apr 14, 2011 | 12:06 AM
Bill Dearborn's Avatar
Bill Dearborn
Disconnect your rear brake lines from the calipers and see if you get fluid draining out of them. The rears are on two separate circuits. Right rear and left front are on the same circuit and left rear and right front are on the other. If you have fluid coming out of the lines then there may be a blockage in the caliper. You could try and pull the bleed screws out and let the car sit for a while and see if the calipers start to gravity bleed.
Bill
Old Apr 14, 2011 | 12:55 AM
Robls6's Avatar
Robls6
Dumb question, but the bleeders are pointed up, right?
Old Apr 14, 2011 | 12:32 PM
PILLAR's Avatar
PILLAR
Yep they r....
Old Apr 14, 2011 | 12:37 PM
LEAVINU's Avatar
LEAVINU
... Gotta start here.
Old Apr 14, 2011 | 12:38 PM
PILLAR's Avatar
PILLAR
Thank you Mr Dearborn. I took the bleed screws out for an hour while I was getting ready for work and got nothing. I will pull the lines when I get home tomorrow.
>>>>>>>>>>Pillar
Old Apr 15, 2011 | 03:25 PM
PILLAR's Avatar
PILLAR
Ok I took the bleeders off and let it sit for several hours..... Nothing. Then I pulled the rear lines anklet it try to gravity feed for a couple of hours. I only got a couple of drips out on each line. I also tried to bleed the brakes using the brake lines instead of the bleeders ... Nothing it's like the brake pedal is doing nothing to the rear brakes.... U can here the front moving when I get my wife to press them but nothing is happening in the back... Please help I need to get this car bach on the road...... Thanks Pillar
Old Apr 15, 2011 | 03:37 PM
takeman's Avatar
takeman
St. Jude Donor '10
This also may sound dumb, but did you check the brake fluid level after bleeding the fronts & top it off?
Old Apr 15, 2011 | 03:41 PM
PILLAR's Avatar
PILLAR
Yes I've bleed brakes many times before and never had this problem....
Old Apr 15, 2011 | 04:10 PM
PILLAR's Avatar
PILLAR
Ok maybe this will help I was sitting in the car beating my head against the steering wheel and I bumped the start button and the car started without me touching the brake pedal. Is it possible that the pedal is stuck downsomehow and I'm the brakes arnt building any pressure....... Help
>>>>>>>>>>Pillar
Old Apr 15, 2011 | 05:35 PM
PILLAR's Avatar
PILLAR
Ok I figured it out... Y'all r going to laugh... My wife was helping me and some how a trim piece under the dash fell down and wasn't allowing the brake peddle to travel all the way.... Thanks for the help
>>>>>>>Pillar
Old Apr 15, 2011 | 05:51 PM
calemasters's Avatar
calemasters
Interesting. Glad you figured it out.
Old Apr 15, 2011 | 09:07 PM
fperra's Avatar
fperra
Murphy strikes again.
Old Apr 15, 2011 | 09:24 PM
VET4LES's Avatar
VET4LES
Common problem. I use a vacuum pump with good luck. Haven't used it on the C6 yet.
Old Apr 16, 2011 | 12:49 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Learn something new every day! Thanks for posting up the solution.
To Zo6 Brake HELP!!!!!!!
