Rear Tire Wear
Old Apr 13, 2011 | 10:31 PM
8206vett's Avatar
8206vett
4th Gear
Default Rear Tire Wear
Me and my wife have had our '06 out for about a month, stored at our house for winter, and noticed the rear wheels are completely balled evenly across. We had new tires put on last September,Firehawk Wide Oval RFT, drove it for two months and put away the beginning of November. The only extensive driving was down to Corvette Expo which was about a 6 hour drive last month. What could be causing the the rear wheels to ware so quickly, the fronts still look new. We are both over 40 and drive both our 86 and 06 like babies. Any thoughts or info would be appreciated. We are also running Nitrogen in the '06 tires.
Old Apr 13, 2011 | 10:41 PM
nitrouser's Avatar
nitrouser
Navigator
some one took you car out with out you permission
Old Apr 13, 2011 | 10:42 PM
nitrouser's Avatar
nitrouser
Navigator
i ment to say your car not you car.
Old Apr 14, 2011 | 12:50 AM
fnsblum's Avatar
fnsblum
Excessive wheel spin? Posi/limited slip locked up full time? Later! Frank
Old Apr 14, 2011 | 07:52 AM
Walt White Coupe's Avatar
Walt White Coupe
I'd like to see some picture because this makes no sense at all.
Old Apr 14, 2011 | 01:38 PM
Kenny94945's Avatar
Kenny94945
Best answer above is someone borrowed your car.
Excess burnouts.
Even wear across both tires, so that implies alignment is good.
We can guess you monitored your tire pressures, yet your standard pressure setting was not mentioned.
On your trips did you load heavy luggage into the trunk or tow an autocross trailer?
You have mentioned time but not mileage.
Is 15K mileage the average for a set of rear Firestones? Maybe.
Else, I guess the only other option would be the rubber compound was defective. Yes, a picture would help.
Old Apr 14, 2011 | 05:08 PM
KB9GKC's Avatar
KB9GKC
Old Apr 14, 2011 | 05:28 PM
Cool Ray 95355's Avatar
Cool Ray 95355
Default Tire Wear
Suggest you double check the air pressure and have the alignment double checked. My Firestone dealer did an alignment, put on new Firestone wide oval tires, 12 months later the rear tires were ruined because the alignment was way off. I bought the lifetime alignment, now will take it in there every quarter to have them check it.
Old Apr 14, 2011 | 05:36 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
If the wear is even all the way across, then you had someone help you adjust the tread depth on your tires. Unless you did it by burning the rubber off in the bleach box.
The rear and front will wear evenly if you don't "accelerate" the hell out of the rears and scrub off the rubber.
Elmer
Old Apr 14, 2011 | 06:45 PM
VET4LES's Avatar
VET4LES
Without pictures this post is worthless.
To Rear Tire Wear
