db at 70mph cruise
Old Apr 23, 2011 | 04:16 PM
Randy_medion's Avatar
Randy_medion
Default db at 70mph cruise
Hi, does anyone know if theres any difference in decibels between the LS2 and LS3 when your cruising @ 70mph? Wich engine is the noisiest?
Old Apr 23, 2011 | 06:53 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Even when closed, I think the NPP exhaust on our 2009 LS3 is slightly louder than the exhaust that came on our 2006 LS2. But the difference is not much.
Old Jul 18, 2011 | 01:24 AM
okaythen's Avatar
okaythen
anyone know the crusing decibel level for z06?
Old Jul 18, 2011 | 10:43 AM
Who Needs Turbo's Avatar
Who Needs Turbo
Car & Driver measures the 70MPH cruising dB sometimes. Could only find one model with this test result listed, though...
2008 Corvette Coupe (LS3) = 73 dB
Old Jul 18, 2011 | 11:23 AM
okaythen's Avatar
okaythen
http://www.insideline.com/chevrolet/...and-video.html
z06 carbon 75db
c5 z06 77db
grand sport 72
hmmm 75db...I guess it's not that noisy
Old Jul 18, 2011 | 12:52 PM
Randy_medion
I found out that the LS2 is also 72db, but at 75mph, it was from a German magazine and the brand new Porsche 997 s was about 74db at 75mph
Old Jul 18, 2011 | 01:56 PM
okaythen's Avatar
okaythen
I was thinking that 75 might be too noisy....but I guess sports cars they are all noisy at highway then..
anyone know the decibel level for z06 after you change the tires? I would like that know that
Old Jul 18, 2011 | 01:57 PM
Randy_medion
yeah, at idle the new porsche made less noise but on the highway a little more than the base Vettes
Old Jul 18, 2011 | 02:01 PM
Randy_medion
non runflats are defenitely quieter, I had Michelin PS2's but only for the fist few thousand miles, after that they will make just as much noise as the runflats, but yeah I guess new PS2's are generally quieter, but more unstable at 150+...P.S I think a Z06 will make more noise than the base model no matter what you do, probably because of the wider tires
Old Jul 18, 2011 | 06:13 PM
TMyers's Avatar
TMyers
It is the tires that make the noise. I don't hear the engine. If you really want a whine put on R888's. My stone's are quiter than the goodyears though.
Old Jul 19, 2011 | 10:45 AM
Malco's Avatar
Malco
OK I just took some readings this morning with my Radio shack sound pressure meter. Set in the A weighting.
I have a 2007 Mn Coupe, but I installed NPP mufflers which when closed are a little nosier than stock.
At 70 mph in 6 th gear I got between 72 and 73 db.
I have non run flat Nitto Invos on the car now. Within the next day or so I am changing to Michelin AS-ZP tires and I will take some more readings then.
Old Jul 19, 2011 | 11:57 PM
Malco's Avatar
Malco
I just changed the tires to the Michelin AS+ZPs and took another reading on the same stretch of road. This time I got 71-72db reading.
To db at 70mph cruise
