what LS2 mods
Old Apr 29, 2011 | 01:58 AM
VettMaster's Avatar
VettMaster
6th Gear
Default what LS2 mods
hey , got a c6 2006 convertible and looking for a lil mods to make it run faster and street . already installed borla , LS2 automatic transmission
Old Apr 29, 2011 | 03:06 AM
Loaded08's Avatar
Loaded08
You've been a member for 10 years this is your first post?!??!! Holy Moly!
Anyway, it's taken me a few cars to think about modding cars differently. Figure out what your goals are, then what mods will further those goals. Maybe goals are wider stance or something, or decreasing a lap time, 60-0 stopping distance or just a custom look, but in any case, figure out what you want to achieve and go from there. If you just want a little more power on the street, maybe a CAI is next for you. If you search, you'll find hundreds of threads on the topic.
Increase that 1 post per decade ratio!
Old Apr 29, 2011 | 07:46 AM
VettMaster's Avatar
VettMaster
6th Gear
lool wow time fly so fast ,, omg
VettMaster's Avatar
VettMaster
6th Gear
hahaha that made me laugh loool **** didnt notice this
Old Apr 29, 2011 | 07:48 AM
VettMaster's Avatar
VettMaster
6th Gear
600rwhp
Old Apr 29, 2011 | 08:25 AM
MARSC6's Avatar
MARSC6
Originally Posted by VettMaster
600rwhp
This worked for me http://eastcoastsupercharging.com/SC600.html#sc600c6
Old Apr 30, 2011 | 02:43 AM
SL33PER's Avatar
SL33PER
A Cam, headers, Stall converter, gears and a tune got me to run 10.85 in the 1/4
Old Apr 30, 2011 | 04:50 PM
VettMaster's Avatar
VettMaster
6th Gear
thanks guys 10ish is great
Old May 1, 2011 | 04:12 PM
smurfkiller's Avatar
smurfkiller
600hp to the wheels is a bit of a hefty goal. i would say your probally gonna wanna do forced induction. but 600hp at wheels is close to 700 flywheel thats pushing limits of what engine can handle not to mention trans and diff.i dont know what your budget is, but i see your location says kuwait so i assume your military. i hope you just re-enlisted over there or your a officer. i would say to build a 600rwhp car that will be reliable is gonna set you back somewhere around $20,000. thats assuming you atleast do stronger rod bolts, lower compression alil, build trans, do a converter, maybe beef up diff and twin turbos plus alotta tires and gas. good luck i hope your able to reach your goals. also try posting this in the FI section since there are more than a few people in there with 600+ rwhp.
Old May 1, 2011 | 06:54 PM
MARSC6's Avatar
MARSC6
600rwhp is getting to be pretty common with FI on stock blocks.
I was something like #62 for ECS to make over 700rwhp on a stock block.
Old May 1, 2011 | 07:20 PM
smurfkiller
stock block? you mean completely stock motor? no stronger rod bolts or rods. the only c6 autos ive done over 600whp that were stock didnt get raced or really even driven hard. the most abuse they saw was while we had them on the dyno. i know the stock block will easily handle that kinda power but the thought of the stock rod bolts holding all that stress kinda scares me.
Old May 1, 2011 | 07:37 PM
MARSC6's Avatar
MARSC6
My car is a manual but its still the stock block, clutch, transmission, and rear. The engine has never been opened.
I'm pretty sure all the other cars in the count had stock blocks as well.
Old May 1, 2011 | 07:42 PM
gunterwalker's Avatar
gunterwalker
From: Cape May, NJ; Guntersville, AL; Orange Beach, AL
Great Guys at ECS!!!!! ECS has a ton of cars with over 600 HP with just the SC kit. I'm not trying to turn this into a supercharger fight.
not getting 600 rwhp from any cam and headers.
Old May 2, 2011 | 10:25 AM
TNTC4VETTE's Avatar
TNTC4VETTE
Will work for HPDE time.
The problem with these type of threads is there's never enough info. The OP throws out some arbitrary number, not knowing what direction to head, and everyone jumps in without even asking why.
So, 600 rwhp. Why?
1/4 mile? Dyno bragging rights? Standing mile? Auto-x? Road racing? Something to rapidly dry off the Zaino?
With that info a lot more helpful responses will emerge. You will also get the side benefit of learning a little about supplying mods and other systems involved with building a car right.
To what LS2 mods
