AFR230's on LS2
Old Apr 30, 2011 | 04:05 PM
C7&7's Avatar
C7&7
Default AFR230's on LS2
Anyone running them on the LS2 4 inch bore?
Any problems? What kind of gains did you see?
I'm thinking about these over TF225s.
Old Apr 30, 2011 | 08:36 PM
SpinMonster's Avatar
SpinMonster
PatrickG used them on his L76 which is a 4" bore without issue.
Old May 1, 2011 | 12:44 AM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
The 230 V2 comes in a small bore version
Old May 1, 2011 | 10:45 AM
C7&7's Avatar
C7&7
Has anyone seen power number comparisons between the 230v2 and the TF225?
From what I am reading low end torque loss is to be expected with the 230.
Old May 1, 2011 | 07:31 PM
glenB's Avatar
glenB
go to that l s 1 tech site and search for patrickG check also in the dyno section
To AFR230's on LS2
