Getting info from the ECM, what do I need?
Old May 8, 2011 | 11:00 AM
Ginny C6's Avatar
Ginny C6
CI 6-7-8-9-10-12 Veteran
St. Jude Donor '11
Default Getting info from the ECM, what do I need?
As stated, I want to be able to pull info from the ECM including codes. Is there software and a cord I can hook my laptop to? I don't want to tune, just look.
Old May 8, 2011 | 12:28 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
There are a number of devices to read and clear codes available. But that's all they do. These are available from many of the forum vendors.
Anything more than that, you will need HP Tuners or EFI Live. I have HP Tuners which does all that and more.
Old May 8, 2011 | 01:23 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree. Any number of code readers, (CAN), that will read the codes from the ECU/PCM.
Old May 8, 2011 | 03:04 PM
MARSC6's Avatar
MARSC6
You can get a bluetooth transmitter or a regular cable to plug into the OBD port. It should come with the software to monitor codes and things like temps, speed, and rpms.
Old May 8, 2011 | 08:49 PM
Ginny C6's Avatar
Ginny C6
St. Jude Donor '11
Link or source?
Old May 8, 2011 | 08:55 PM
Motorhead-47's Avatar
Motorhead-47
Originally Posted by Ginny C6
Link or source?
One option.... http://www.ot-2.com/
Old May 9, 2011 | 07:12 AM
REVAK's Avatar
REVAK
Auto Xray makes a scanner only unit, also the diablo predator will read and clear codes, show real time data, and tune if desired. I am not familiar with read only software for laptops. I think you can however go from the predator to your laptop to view data.
Old May 9, 2011 | 12:03 PM
white90conv's Avatar
white90conv
Default Scanning ecm
Go to the Scan and Tune Forum on this site. There are a number of possible options.
Old May 9, 2011 | 11:11 PM
Corvee's Avatar
Corvee
Do not waste your time or money on the OT-2. It will not read the OBDII on my car. Innovate "customer service" is no help.
Old May 10, 2011 | 12:23 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
hp Tuners sells a "dumbed down" cable that scans only, doesn't allow tuning.
http://www.hptuners.com/order.php
But with your cam, you'll want to tweak things and you'll end up wanting the tuner part as well. Trust me. It takes a lot of time to really dial in a car for street driving, and it's fun. It also helps a lot on the track if you do that. Just be sure to get a wideband. The HP Tuners forum has stickies that are very helpful to the newbie, and they have a very active forum for help.
Old May 10, 2011 | 06:18 AM
Motorhead-47
Mine worked fine..no issues.
To Getting info from the ECM, what do I need?
