Battery quick disconnect or tender
Old May 12, 2011 | 11:27 AM
larry48's Avatar
larry48
Default Battery quick disconnect or tender
Hello,
i have a 2005 coupe. With ac delco battery.
I need some advice on putting a battery quick diconnect or a battery tender on the battery. Like most it sets for weeks before i drive it.
Is there computer, other issues with the quick disconnect?
Thanks,
larry
Old May 12, 2011 | 02:43 PM
carpe dm's Avatar
carpe dm
Use a tender. I have used one for many years with no problems. Your battery will thank you......
Old May 12, 2011 | 07:18 PM
AeroJim's Avatar
AeroJim
St. Jude Donor '08-'09
Originally Posted by larry48
Hello,
Thanks,
larry
No issues at all.. I kept a battery tender on my 05 for its whole life until I sold it this year. Its probably the best thing you can do for a car/motorcyle thats not a daily driver. I now keep one on my 2011 GS and both motorcyles
Old May 12, 2011 | 07:29 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
The dead battery syndrome was primarily an issue with the 05's and early
06's. By 07 the issues were worked out by GM. I know when I bought my 07 M6 the salesman told me dont forget to put it into reverse when you park or you will have a dead battery the next day. Well I let it sit for weeks at a time and no Bat problems. i really dont think you need to be doing a Battery tender on a 2011 Corvette. Just my humble opinion but definately on a 05 & 06.
Old May 13, 2011 | 05:32 PM
chargerconnection's Avatar
0chargerconnection
Former Vendor
St. Jude Donor '11
Default StealthLink for Easy Connection of Tenders
StealthLink...The Park-n-Plug Solution for connecting your battery charger. Check us out at:
www.chargerconnection.com
Kits available for Battery Tender, DieHard, Schmacher, & Ctek.
Old May 13, 2011 | 08:21 PM
MARSC6's Avatar
MARSC6
Your battery won't die in a few days like some of the 05s but your battery will still drain over time. Just the way it is with modern cars.
Old May 13, 2011 | 08:24 PM
MARSC6's Avatar
MARSC6
I use a disconnect since I don't like to leave a charger plugged in for long periods of time. Especially in a garage I may not enter for weeks at a time over winter.
Old May 14, 2011 | 09:04 AM
SteveL4446's Avatar
SteveL4446
I use a battery tender connected to the accessory outlet in the center console. That way I notice it right away and have a chance to unplug it rather than dragging it through the garage like I did when I used a quick disconnect and forgot to unplug it. Old age is a bitch!
Old May 14, 2011 | 05:28 PM
smurfkiller's Avatar
smurfkiller
i used to leave my battery in and connected in my truck for 7+ months at a time when deployed in the military came back turned the key started right up everytime. had to put lil air in tires few times but thats it. a tender is not a bad idea but not completely needed.
Old May 14, 2011 | 07:54 PM
VET4LES's Avatar
VET4LES
I have an 05 and never had DBS. When I go on vacation for two or more weeks I disconnect the battery. It always starts right up when connected again.
To Battery quick disconnect or tender
