Heat exchanger
Old May 14, 2011 | 02:09 AM
ktoonsez's Avatar
ktoonsez
Default Heat exchanger
Anyone done a heat exchanger on there C6 for there oil. Here are the dimensions of the one I want:
Measures 10" long x 4" wide x 4.5" tall.
I am looking for ideas on where to put it and how you mounted it? Did you weld a plate or bolt it up? What kind of tubing did you use to go from radiator to heat exchanger to water pump?
Ken
Old May 14, 2011 | 08:19 AM
Dan Wendling's Avatar
Dan Wendling
Default EOC Radiator
Why not go the simple and proven route and install a EOC equipped radiator?
Ron Davis and others make a good quality product, and they can help you with the required adapters and oil lines.
Old May 14, 2011 | 09:24 AM
ktoonsez's Avatar
ktoonsez
I already have a Ron Davis with EOC. Temps are too high on hot days on the track so need to ge them down.
Old May 14, 2011 | 12:50 PM
07MontRedcp's Avatar
07MontRedcp
PM forum member "Wayne 0". He's in Tucson, but comes up here all the time to track his car.
BJK
Old May 15, 2011 | 02:28 PM
ktoonsez's Avatar
ktoonsez
ttt
Old May 16, 2011 | 06:52 PM
ktoonsez's Avatar
ktoonsez
evening bump
Old May 18, 2011 | 10:21 AM
ktoonsez's Avatar
ktoonsez
ttt
Old May 18, 2011 | 10:55 PM
Joe_Knesek's Avatar
Joe_Knesek
I have a C&R heat exchanger but have not installed it yet. I'm not sure what to do about the water lines.
Old May 21, 2011 | 06:28 PM
ktoonsez's Avatar
ktoonsez
ttt
Old May 25, 2011 | 12:17 AM
ktoonsez's Avatar
ktoonsez
ttt
Old May 25, 2011 | 08:01 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Will the large C6Z06 stand alone cooler not work good enough? I ran one on track and never had oil temp issues.
Old May 25, 2011 | 09:09 PM
ktoonsez's Avatar
ktoonsez
No, not enough cooling power, I hit 275 degrees 2/3rds the way thru a 20 minute session on warmer days. Could go with a Setrab #172 but I can get a heat exchanger at same cost, cheaper actually, so I might as well go for the better device that has way more BTU cooling power.
Old May 26, 2011 | 10:49 PM
ktoonsez's Avatar
ktoonsez
ttt
Old Jun 13, 2011 | 03:31 PM
ktoonsez's Avatar
ktoonsez
bump
Old Jun 13, 2011 | 06:17 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
275' is pretty tame, the oil temp won't run the cooling fan on high until the oil gets to 302', and the hot oil message comes on at 320'. That, for our 20069 LS3.
Maybe run 0W-40 just for track days, if you want a bit more protection?
Old Jun 13, 2011 | 06:25 PM
ktoonsez's Avatar
ktoonsez
Well you have to remember that that light is assuming that you are driving normal too I would think. I do run a 15-50 oil to help but still don't like it. Running 300+ oil temps constantly at 3500 to 6700 RPM is gonna severly reduce engine life in my opinion, so why not be safe.
Old Jun 14, 2011 | 11:54 PM
ktoonsez's Avatar
ktoonsez
Found this stuff today called Vulco Flex® II made by Gates, looks promising for the coolant plumbing. Anybody ever use it?
http://www.jegs.com/webapp/wcs/store...-1&showValue=1
To Heat exchanger
Old Jun 23, 2011 | 07:57 PM
ktoonsez's Avatar
ktoonsez
bump
Old Jun 23, 2011 | 08:52 PM
timd38's Avatar
timd38
I must be missing something. I just bought a Z06 cooler and the thing is huge. If that won't keep the oil cool, you have other issues.
Old Jun 23, 2011 | 09:08 PM
ktoonsez's Avatar
ktoonsez
I have never tried it but didn't want to waste the money if it didn't have the BTU power of a Heat Exchanger.
