Squealing Noise
Old May 15, 2011 | 02:38 PM
66biskwik's Avatar
66biskwik
Default Squealing Noise
I have a squealing noise when I'm in 5th or 6th gear at a low rpm and accelerate. It won't do it in any other gear. It sounds like a belt squealing. If you push the clutch in and let it out it goes away. There is no squeal if you rev the car up in neutral. I was thinking a pilot or throw out bearing but wouldn't it do it all the time? The car has a Mcleod dual disc clutch and also a Comp Cams belt tensioner. Not many miles on setup. I know someone will say don't drive it so slow.
Just wondering if anyone has experienced this problem?
Old May 23, 2011 | 12:23 AM
Rafal's Avatar
Rafal
bump because I think I have the same problem.
it sounds like some belt but won't hear it when at idle, only if in a gear. when i press the clutch, it goes away.
any ideas?
