Changing Fan Temp on C-6
Old May 15, 2011 | 02:54 PM
Roger McTighe's Avatar
Roger McTighe
Navigator
Default Changing Fan Temp on C-6
Can you change the temp that the fan comes on without bying a programmer?
Old May 15, 2011 | 11:27 PM
smurfkiller's Avatar
smurfkiller
yes take it to a tuner. a crappy hand held programmer wont change fan temps anyway. alot of places will charge minimal fee to turn down fan temps,turn off torgue management,reset rev limiters etc. just keep in mind hp tuners charges $100 to unlock your computer so its gonna cost atleast that much. but that is a one time only fee.
Old May 16, 2011 | 07:33 AM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
What problem are you trying to fix?
Old May 16, 2011 | 11:36 AM
smurfkiller
id would assume to go with a colder thermo.
Old May 16, 2011 | 05:46 PM
Mez's Avatar
Mez
Its not that simple.
The fans are variable speed. They are not simply on or off. You set the % speed at various engine coolant temps.
Setting the fans to come on at 190° when it has a stock 194° thermostat won't do any good. The fans will be running but the thermostat will still keep the coolant at 194°. The problem also is the fan may overheat and burn out because they are not designed to run at 100% duty cycle.
This is why I was asking what problem the OP was trying to solve.
Old May 16, 2011 | 08:05 PM
truckplay's Avatar
truckplay
You can get a mail order tune from ECS for $150. It is worth it.
Old May 16, 2011 | 10:06 PM
smurfkiller
yes the fan is not just a on off. so OP why do you want ot lower fan temps?
Old May 16, 2011 | 11:10 PM
Mez's Avatar
Mez
Its a little soon to suggest a tune when the problem has not been outlined.
Old May 17, 2011 | 12:26 AM
fnsblum's Avatar
fnsblum
Deleted!
Old May 17, 2011 | 12:28 AM
starr719's Avatar
starr719
Old May 18, 2011 | 01:44 PM
REVAK's Avatar
REVAK
To the best of my knowledge, you can not change the temperatures, but you can change the percentages for each temp. range. It does require a programmer or hp tuners, etc. to effect the percentage changes.
Old May 18, 2011 | 03:51 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Thanks, OP we can handle fan temps along with any other bolt on modifications with our mail order tune special.
To Changing Fan Temp on C-6
