need some help
Old May 21, 2011 | 02:08 PM
JoesC5's Avatar
JoesC5
Default need some help
While not paying attention(happens a lot recently) I scratched the heck out of my air breather housing on my Z06. I purchased a replacement but I read on this forum that the screws holding the MAF are special 5 point torx instead of the normal 6 point torx used elsewhere on the car. I've checked Harbor Freight and O'Rielly's for a 5 point torx driver to no avail.
You guys that changed out your air intake in your driveway, where did you find the 5 point torx driver? I think it's a #10, but not sure.
Old May 21, 2011 | 05:43 PM
JoesC5's Avatar
JoesC5
27 have viewed my post. 27 have wax under their fingernails and 0 have grease under theirs.
Old May 21, 2011 | 06:10 PM
Ragtop 99's Avatar
Ragtop 99
i don't remember needing anything special. Did you actually go out and check?
Old May 21, 2011 | 06:46 PM
EVRose's Avatar
EVRose
Sears has a tool that has multiple security tips including what your talking about. It's about $20 and is one of the most used tools I have in my tool box.
Well, it's $25. This is the one I have.
Security bit tool.
Old May 21, 2011 | 08:05 PM
Motorhead-47's Avatar
Motorhead-47
I gotta believe this $10.00 "security torx bit" set from HF would have what you need.
http://www.harborfreight.com/100-pie...set-91310.html
Old May 21, 2011 | 09:32 PM
JoesC5's Avatar
JoesC5
Thanks. I'm going to head back to harbor freight. I didn't find that set when I was there last week.
BTW, while doing a search on the web(after I made my initial post) I came across a post on another forum that said the 2006 Z06 and very early 2007 Z06's had the 5 point torx and the newer cars have the standard 6 point torx. Because I read on this forum about the special screws I assumed my car also had them. I guess I should get a 6 point torx bit out of my toolbox and see if does work. Might save me a trip and $10.
Old May 21, 2011 | 09:45 PM
smurfkiller's Avatar
smurfkiller
vise grips, cut a slot in it remove with screwdriver, be creavative if you have to. i have never seen a 5 point torx. hmm interesting.
To need some help
