Rear gear
Old May 23, 2011 | 08:51 PM
Bill K C6's Avatar
Bill K C6
Default Rear gear
Who makes rear end gears for for 05 c6 what is the name of the rear end? Would a stall converter help on a c6 with stock cam it does have headers and exhaust and if so what stall speed? Thanks
Old May 23, 2011 | 11:47 PM
cranky's Avatar
cranky
call tj at RPM TRANSMISSIONS a forum vendor. they are a top notch vendor in this area. tj will be very helpful with info you need. have done business with them and reccomend them highly.
Old May 24, 2011 | 12:31 AM
Sparo2's Avatar
Sparo2
The rear gear is called the ring and pinion. There are a few companies that make them. RPM can help you out. A 2800-3200 stall converter will work good for a daily driver. Just be sure to match your cam and converter.
Old May 24, 2011 | 01:10 PM
Ragtop 99's Avatar
Ragtop 99
A stall will make a big difference in performance, more than the gears. LS motors love high stall. 2800 - 3600 for for your average street and strip user. For the 05, 3.42s and 3200 is a pretty nice combo for a mostly street car. The combination of 3600 stall + 3.73s + tires makes for a very effective drag race car.
To Rear gear
