Need alignment specs for Performance Street
Old May 24, 2011 | 05:41 PM
DRLC5's Avatar
DRLC5
Default Need alignment specs for Performance Street
I have a 2011 GS With 19/20 wheels. Running 285 fronts and 345 rears.I have an appointment next week for an alignment looking for specs if available? I saw specs from Pfadt but I think they were for a bace c6? Car is lowered all the way on stock bolts. Would it be the same with my set up?Thanks in advance.
This is what I will be going with. The first alignment Street Performance.
http://www.pfadtracing.com/blog/wp-c...-alignment.pdf
Old May 24, 2011 | 06:04 PM
Boomer111's Avatar
Boomer111
Not sure about you situation but I have Pfadt street alignment and the car handles great.
Old May 24, 2011 | 08:21 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
Do you have the 1) Performance Street alignment or 2) the Performance Street-Track Use w/ Street Tires alignment?
Old May 24, 2011 | 09:18 PM
johnodrake's Avatar
johnodrake
Moderator
Ditto
Old May 24, 2011 | 09:32 PM
JoesC5's Avatar
JoesC5
I have the max of the Performance Street settings on my Z06. Looking for good tire wear but not kill all handling.
-0.9 degree front camber and -0.6 degree rear camber. As close to zero toe as possible front and rear, but no toe out.
Old May 24, 2011 | 09:40 PM
DRLC5's Avatar
DRLC5
Sounds good, What size tires are you running? Thanks for the info.
Old May 25, 2011 | 09:33 AM
Boomer111's Avatar
Boomer111
I have the Pfadt street only spec. -0.8 front camber and -0.5 rear camber, with front total toe of .13 and rear total toe of .02.
Old May 25, 2011 | 09:57 AM
JoesC5's Avatar
JoesC5
stock sizes
Old May 25, 2011 | 09:59 AM
Kneel 8250's Avatar
Kneel 8250
St. Jude Donor '11-'12
Fitted new tires last week and alignment to minimum PFADT performance street/Track. No2 on the PFADT sheet.
Michelin 295 f 345 r
-1.1 f cam -0.7 r cam -1/16 toe f -1/16 toe r
Feels great on the street and a little understeery/pushy mid corner on the track. Thinking seriously about having a street setup and a track setup.
Hope that helps some.
Have a great day.
Kneel.
Old May 25, 2011 | 09:11 PM
TLTONEY's Avatar
TLTONEY
Watching this for specs. I need a good setup, but need to keep the tires from getting ate-up as my car is a DD.
Old May 25, 2011 | 09:54 PM
Boomer111's Avatar
Boomer111
Mine is a fun only car so does not see many mile, maybe a tankful a month. Tires will grow old before I wear them out so I was not to concerned with Pfadt street numbers.
Has to be proven to me anyway how they will wear.
Old May 26, 2011 | 11:12 PM
DRLC5's Avatar
DRLC5
Thanks to all for the info, Good reading..
I will be going with the street alignment, The first one on the page.
Old May 27, 2011 | 09:36 AM
upsta8NY's Avatar
upsta8NY
I did the first one and what a difference even on runcraps,but they are grtting changed today.
Old May 27, 2011 | 05:56 PM
Pfadt Racing's Avatar
Pfadt Racing
Hey guys! Thanks for posting info on our specs. I figured I would just add a direct image for people to reference:
you can click on it for a larger image.
Old May 28, 2011 | 08:31 AM
Kneel 8250's Avatar
Kneel 8250
The Pfadt alignment specs allow less error and are more moderate in the first street application than the factory specs.
If you are concerned about tire wear I would go with the Pfadt alignment specs.
Kneel.
Old May 29, 2011 | 04:01 PM
Bandit1's Avatar
Bandit1
To Need alignment specs for Performance Street
