Rear View Mirror Reinstall - HELP
Old May 29, 2011 | 07:59 PM
92Beast's Avatar
92Beast
Default Rear View Mirror Reinstall - HELP
Was trying to install the radar detector blend mount today. Really a tight fit. Was pushing the mount up along the windshield and the darn mirror popped off.
Looked in my field manuals but did not find how to solve this. It almost looks like it takes a special tool to release the tension on the ring spring that locks on the mounting nut attached to windshield.
Anybody know the answer?
Old May 29, 2011 | 08:13 PM
RicK T's Avatar
RicK T
Place the mirror up to the windshield at about 30-45 degrees off horizontal, counterclockwise, push onto the stud and twist clockwise to horizontal at the same time.
Old May 29, 2011 | 08:21 PM
92Beast's Avatar
92Beast
Hey thanks Rick. See you are nearby neighbor.
Old May 29, 2011 | 08:38 PM
RicK T's Avatar
RicK T
Sort of.
Get the mirror back on okay?
Old May 30, 2011 | 03:37 PM
92Beast's Avatar
92Beast
It went back on just like you said. Finished mounting the blend mount and installing the RD. Thanks again for the help.
Doug
Old May 30, 2011 | 04:37 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Doug
The real question.....
Are you ready?
Does the mirror NOW have a vibration when you drive? Are the objects in the mirror blurry now due to a vibration in the mirror mount?
When I took my mirror off and replaced it, the damn thing was loose and it took special metal pins to replace the stock pins as the OEM pins had bent and allowed a "slack" fit when it was reinstalled.
Elmer
Old May 30, 2011 | 05:53 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
My understanding is that you can remove the pins and straighten them to fix the problem.
Old May 30, 2011 | 06:17 PM
92Beast's Avatar
92Beast
Elmer:
It seemed to install tight but I have not driven it since I reinstalled the mirror. I will repspond after I take if for a drive.
May need the instructions to install new pins.
Doug
Old May 30, 2011 | 06:20 PM
eboggs_jkvl
Moderator emeritus
Did that twice. Didn't fix the issue. The damn pins bent immediately upon reinstall each time. Once they bend, they are dead meat.
Old May 30, 2011 | 09:02 PM
92Beast's Avatar
92Beast
Thinking about this a little more, I don't think I will have the problem with vibration. When you install the Blend Mount radar detector mount it fits tightly between the mirror arm and the inner windshield which I belive will stablilize any vibration that may have occured due to the mirror popping off.
We will see.
Doug
Old May 31, 2011 | 01:28 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Elmer
Elmer:
Where did you get the "special" pins ?
Old May 31, 2011 | 01:37 PM
eboggs_jkvl
Moderator emeritus
Elmer:
Da man! "bassspring" He has the super secret stainless steel spring pins.
Of course, now I'll have to kill ya since you know the super secret answer to the mirror problem.
I PM'd him and he sent me some pins. He needs to go into business on these things! He sent them free but I was a smart-butt and sent him some money to cover his very kind gesture.
Elmer
Old May 31, 2011 | 03:18 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Please don't kill me, I'll keep it secret!
Thanks Elmer
Old May 31, 2011 | 03:23 PM
RicK T's Avatar
RicK T
Thanks Elmer
You gotta be careful with Elmer.
To Rear View Mirror Reinstall - HELP
