Best brake fluid?
Old May 30, 2011 | 11:33 PM
TSLAVette's Avatar
TSLAVette
Default Best brake fluid?
What are you guys using? Have a 2008 with Z51 brake package (part of F55). Anyone know the capacity? Tips on changing fluid (also installing Delco ceramic pads)? Thanks!
Old May 31, 2011 | 06:04 AM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
The best fluid IMHO is Castrol SRF. Overkill for most. ATE Type 200 and Super Blue are good fluids and are different colors so you can tell when the old fluid is flushed.
San
Old May 31, 2011 | 10:36 AM
epic's Avatar
epic
I'm using Motul RBF600 Synthetic DOT 4 Brake Fluid. Awesome stuff.
Old May 31, 2011 | 11:45 AM
ScaryFast's Avatar
ScaryFast
For street use just get Autozone stuff. Don't waste your money on fancy fluids.
For track use, the Motul and Castrol SRF are great but expensive. The ATE is good and is what I use. Look at the WET boiling point of these brands if you want to know how to compare them. The dry boiling point is fresh from the can, the wet point is the real world - it means the boiling point once the fluid has absorbed water from the atmosphere, which pretty much happens as soon as you open the bottle.
Old May 31, 2011 | 12:49 PM
el es tu's Avatar
el es tu
Castrol srf is 70 to 80 bucks a bottle. It has been one of the higher regarded brake fluids for a while now.
Ate gold/blue fluids will run you 10 to 15 per bottle and recieve good reviews.
If/when you race go for the better one.
With the ceramic pads Im assuming youre not that concerned about the track - save the money and get the ate.
good luck!
Old May 31, 2011 | 01:31 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Ditto
Old May 31, 2011 | 01:36 PM
KneeDragr's Avatar
KneeDragr
I like ATE superblue because it comes in both an amber and a blue color. So what you do it fill it up with blue, and then when you flush you put in amber and can tell when the blue is flushed out of the caliper when the color changes fully to amber.
Old Jun 1, 2011 | 02:29 PM
acrace's Avatar
acrace
Another vote for the ATE Super Blue and ATE Typ 200 (the amber color version of Super Blue). Just like previous posters have stated, it makes it easy to know when you've flushed out all of the old stuff. I've been very happy with its performance and it's reasonably priced.
Old Jun 1, 2011 | 05:19 PM
TSLAVette's Avatar
TSLAVette
Thanks! What's the capacity (how much will I need for a flush?)
Old Jun 1, 2011 | 06:37 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
I used two 500ml containers of Motul RBF600 to flush my system.
To Best brake fluid?
