After spending more time looking through more repeat posts than I could ever put up with again, I have come to a stopping point.
The following suspension setup is what I have come up for a base model coupe. The goal was to use all oem parts, come up with something more aggressive than the Z51, but more balanced than the Z06.
I have included a table with the spring and sway bar rates:
This setup should be stiffer than the Z51 ride, and dial out some understeer while maintaining Z51 balanace.
Right now the only hard decision is Z06 shocks or bilstein sports... Do I want even better performance or factory looks...
