c6z06 rear diff in base 05 c6 ??
Old May 31, 2011 | 10:00 PM
1bigcam's Avatar
1bigcam
Default c6z06 rear diff in base 05 c6 ??
Trying to find out whats all needed besides the c6 z06 diff to install it in my 05, i did do alittle serching but came up empty thanks for any help
Old May 31, 2011 | 10:13 PM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
I am assuming you have a manual trans car. You will need to remove the transmission and have the mainshaft changed to a 06-07 Z06 30 spline shaft. Then the transmission tailhousing will need to be swapped out to a 06-07 base (Non-Z06) tailhousing. The differential will bolt up at that point but you will still need to address the differential cooling system or remove it completly. Feel free to give us a call to go further into those options. 1-800-406-1109
Old May 31, 2011 | 10:35 PM
1bigcam's Avatar
1bigcam
How about the rear cradle ? It need changed
Old May 31, 2011 | 10:37 PM
Former Vendor
Nope
Old May 31, 2011 | 11:27 PM
1bigcam's Avatar
1bigcam
Would it be better to just put the z06 trans in also?
Old Jun 1, 2011 | 10:20 AM
Sparo2's Avatar
Sparo2
ZO6 trans has taller gears. Just depends on what you want. Personally, if I had the ZO6 trans I would throw it in since it's all apart.
Old Jun 1, 2011 | 10:25 AM
APSGTO's Avatar
APSGTO
Unless he has a Z51 which his signature says base, then the trans ratios will be the same.
Old Jun 1, 2011 | 03:11 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
I just finished doing one:
http://forums.corvetteforum.com/c6-t...lmost-10s.html
It started off as just a motor swap but he got a good deal on the diff and trans so I ended up doing that too.
Old Jun 1, 2011 | 05:26 PM
corvet786c's Avatar
corvet786c
Not trying to hijack this thread but can a 08 base c6 transfer to a c6 zo6 differential? What changes would need to be made?
Old Jun 1, 2011 | 05:32 PM
thesubfloor
I assume you're talking about putting a C6 Z06 differential into a 2008. If that's the case then yes in an automatic car and no if it's a manual unless you change some of the transmission internals as mentioned earlier in the thread.
Oddly enough, a Z06 differential will only bolt up to either a Z06 transmission or an A6 but not a regular M6.
Old Jun 1, 2011 | 05:35 PM
corvet786c's Avatar
corvet786c
I am talking about a M6 the 08's are diffrent from the 05 though?
Old Jun 1, 2011 | 05:37 PM
thesubfloor
I usually deal in automatics so I'm not 100% on this, but I'm pretty sure you still have to change the mainshaft in an 08 trans but don't have to change the tailhousing.
Old Jun 1, 2011 | 05:38 PM
corvet786c's Avatar
corvet786c
alright just wondering!
Old Jun 1, 2011 | 10:08 PM
1bigcam's Avatar
1bigcam
I was told i cant put the z06 trans in because my car has the shift to reverse thing?
Old Jun 1, 2011 | 10:26 PM
RicK T's Avatar
RicK T
Check this thread:
http://forums.corvetteforum.com/c6-t...nsmission.html
Old Jun 1, 2011 | 10:36 PM
1bigcam's Avatar
1bigcam
Sounds like i should not do this, just trying to come up with a combo that will hold up and not be $100,000
Old Jun 2, 2011 | 04:44 AM
Icevettez06's Avatar
Icevettez06
I have taken out the 2007 Z06 T56 which has the 2005 case with the hole for the plug for C6 2005. Transmission is in 100% condition. I did put in TR6060. I ´m willing to sell the T56.
To c6z06 rear diff in base 05 c6 ??
Old Jun 2, 2011 | 10:55 AM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
08 will have the TR6060 with a 27 splined main output shaft. Change it with the Z06/ZR1 30 splined main shaft and the C6 Z06 diff will be a bolt in.
__________________
Old Jun 2, 2011 | 10:57 AM
Supporting Vendor
Mike, a 06-07 T56/Z06 diff set up will be more than enough for your needs.
Old Jun 2, 2011 | 08:04 PM
1bigcam's Avatar
1bigcam
Yeah thats what i would like to use but i dont want any lights or something lit on the dash, do you know of a way to do that swap with out any problems
