Differential Oil Change Tip
Old Jun 3, 2011 | 07:10 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Default Differential Oil Change Tip
Changed my Diff oil yesterday and wanted to pass on a tip for anyone else doing the job. The job was a breeze because I went down to Harbor Freight and bought a small hand operated transfer pump ($3.99) which comes with plastic inlet and outlet tubing that each are about 24" long. This allows you to put one hose into the hard to reach fill port, the other hose into the Dexron 75W-90 oil container a couple of feet away and pump away while sitting on the garage floor, instead of trying to get a container with a hose on it up by the differential fill port while lying on your back trying not to spill it on yourself. Makes this job a piece of cake.
Old Jun 3, 2011 | 07:43 PM
Twisted1's Avatar
Twisted1
I like that idea.
Finally something for a vette that doesn't break the bank....or even the piggy bank.
Will have to go pick one up.
Thanks!
Twisted1
Old Jun 3, 2011 | 08:39 PM
66biskwik's Avatar
66biskwik
Question. I have had many high performance street cars and have never changed the rear end oil unless for a gear change. Never had a problem and I don't baby them. Do these cars really need to change out the oil because of the design or just another money making GM deal. Figuring the customer will bring them back to the dealer?
Old Jun 3, 2011 | 09:20 PM
VET4LES's Avatar
VET4LES
I have a hand pump and used it for years. It work's great.
Old Jun 3, 2011 | 09:29 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Actually, I don't think it's a scheme to rid you of dollars. In some cases, it may not be absolutely necessary every 15K miles (but no one's recommending that sched either), but there seem to be some inherent issues with the rear fluid which impacts the rear end itself. From what I've read, GM went thru 3 different or modified fluids to get to what they consider to be the proper fill. That's over a period of about 4 model years of C6s.
IMO it's very cheap insurance.
Old Jun 4, 2011 | 12:54 PM
Mark VerMurlen's Avatar
Mark VerMurlen
If I remember right, the owner's manual recommends that the diff fluid be changed after a cumulative 24 hours of autocrossing or HPDE activity. That's probably because of the heat that gets generated in the diff under those conditions breaks down the fluid. So I change mine every couple of years since I'm only occasionally at the track. I do it myself, so the only cost is the new gear lube. If you only run your car on the street, I wouldn't worry about it.
- Mark
Old Jun 4, 2011 | 01:04 PM
66biskwik's Avatar
66biskwik
Thanks.
Old Jun 4, 2011 | 01:23 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Mine was starting to get a little noisy sometimes on tight turns (clutches sticking) and the last time it was changed it was before the latest Dexron 75W-90 fluid was recommended by GM. Mine had the previous generation oil with separate friction modifier added, so I figured it was time to get the newer stuff put in.
Old Jun 4, 2011 | 01:35 PM
Street Rat's Avatar
Street Rat
The hand operated pumps are the only way to go!
Old Jun 4, 2011 | 04:33 PM
wbear's Avatar
wbear
Sub, do you have brand name/part # for the pump? I don't have a HF near me but I could look up info on it with the name to see who else has it. If not the HF # would do.
Good move changing to the new oil, smooth as silk.
Old Jun 4, 2011 | 05:15 PM
crusher1's Avatar
crusher1
Hey Sub is his the one you bought??
http://www.harborfreight.com/multi-u...ump-66418.html
Old Jun 4, 2011 | 05:58 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Go on the Harbor Freight Website and search "Transfer Pump", which will take you to Item #66418, now showing a price of $5.99.
Old Jun 4, 2011 | 05:59 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
That's the one.
Old Jun 4, 2011 | 06:14 PM
ALS 08's Avatar
ALS 08
Old Jun 4, 2011 | 06:40 PM
wbear's Avatar
wbear
Ah that one! I've been using those for almost 30 years. Bought 2 and wore one out. Have the other still in the box, hope the material hasn't deteriorated too much.
I've been using a marine lower unit lube pump from Walmart that screws on to a quart bottle that pumps with your thumb. Slow and needs to be close but it works.
Old Jun 4, 2011 | 08:55 PM
Gering's Avatar
Gering
Tolero Apto Victum
It may not be needed, but I like to drain & fill the diff & trans (with new filter) every 20,000 miles. IMO it is easy, cheap, and gives me good piece of mind. Like you, I love to drive my Vet (07 A6 with over 110,000miles on it).
To Differential Oil Change Tip
