New dyno numbers!!!
Old Jun 4, 2011 | 10:42 AM
kboboz71's Avatar
kboboz71
Default New dyno numbers!!!
Well I just took my car to Dallas performance today with the new setup, which consists of:
Procharger d1sc 3.85 pulley a&a bracket
DP flip drive 6 rib
Hinson poly motor mounts
A-1000 in tank pump w/ full return fuel system 83lb Inj.
Snow performance dual nozzle meth kit
McLeod rxt twin disk billet fw
Rx catch can
Tick adj. Master
I am running the same h/c/I/e setup as when I was n/a and made 500rwhp.
First off let me start by saying that Taylor and Chris and the other guys up there are top notch. I have had dealings with several performance shops in the last few years and have ALWAYS been dissapointed in the customer service. But the guys at DP are very customer service oriented and strive to make sure you are completely satisfied before you leave, so up for DP!! anyway, to the numbers.
11psi
15-16* timing
a/f 11.0-11.2
Final numbers 744/630 sae corrected!!! I had him stop there due to the stock bottom end, i didnt wanna push it. Taylor said he could have made another 40rwhp or so! I'm very happy with the results, it is an absolute beast! The boost is awesome!! Now to go enjoy it, and get it to the track soon!
Old Jun 4, 2011 | 10:47 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Those are serious numbers. Congrats.
Old Jun 4, 2011 | 11:20 AM
JayplaySS2's Avatar
JayplaySS2
What are the cam and head specs?
Old Jun 4, 2011 | 12:42 PM
kboboz71's Avatar
kboboz71
Specs are in my sig
Old Jun 5, 2011 | 12:06 AM
kboboz71's Avatar
kboboz71
What kind of timing are you guys with prochargers running? 15* seems real low, just wondering what I could go up to on meth?
Old Jun 5, 2011 | 12:41 AM
Slwsvt's Avatar
Slwsvt
With the meth setup, 15 degrees if very very safe. You could easily tune in 3-4 more degrees of timing and make another 50rwhp with the meth. But, with the summer heat, not a bad idea to keep the timing down.
Old Jun 5, 2011 | 01:41 AM
kboboz71's Avatar
kboboz71
Yeah I figured so, I was just wondering. I know Taylor knows what he's doing. He's the best tuner I've seen, by far.
Old Jun 5, 2011 | 09:41 PM
JWell's Avatar
JWell
WOW...that's a serious fuel system
Old Jun 6, 2011 | 10:00 AM
FloydSummerOf68's Avatar
FloydSummerOf68
Specs are in my sig
Your sig isn't showing up.
Old Jun 6, 2011 | 10:11 AM
kboboz71's Avatar
kboboz71
Well I don't know why, I just copied this from it, here y'all go:
06 c6 z51
afr 205's, milled .040, arp head bolts, pinned crank
custom grind cam 231 239 644 651 114 +2
Ported Fast 102/NW 102
vararam ram air
kooks 1 7/8 long tubes, kooks 3in. mid, npp mild to wild
exedy twin disk
mgw shifter
z06 output shaft, z06 small shafts in diff, 3.73's
pfadt coilovers
Old Jun 6, 2011 | 12:04 PM
SpinMonster's Avatar
SpinMonster
How do you like the gears with 700+HP?
Old Jun 6, 2011 | 12:29 PM
kboboz71's Avatar
kboboz71
Man I haVnt been able to play with it a whole lot but with the z51 tranny and 3.73s, u don't have much time to enjoy it until u Get into fourth gear lol. It's insane
To New dyno numbers!!!
