LS3 Oil Pump
Old Jun 6, 2011 | 02:03 PM
todm's Avatar
todm
Default LS3 Oil Pump
I have a 2009 Z51 that I had to have the oil pump replaced on just a few months ago. Now, this morning, it appears to have gone again as I have no oil pressure. The car has 15,000 miles on it. What could be the problem with the oil pumps? Is there a problem with the oil pumps in the LS3 engine?
Old Jun 6, 2011 | 03:27 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
The oil pumps are driven off the front of the crank shaft, so they are pretty fool proof. What can be a problem is the 'O' ring on the pick up tube. They may not seat correctly so it will suck in air.
Old Jun 7, 2011 | 12:29 PM
ls3gotcha's Avatar
ls3gotcha
Iagree with the poster above
Old Jun 7, 2011 | 03:03 PM
theofel's Avatar
theofel
St. Jude Donor '10-'13
May not be the pump itself. Check the oil pressure sending unit.
Old Jun 8, 2011 | 10:49 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
The LS pumps have a notorious history of the pressure relief valve sticking...check with the dealer as I believe there are several Technical Service Bulletins (TSB) outlining the scope and fixes.
To LS3 Oil Pump
