Dyno graph needed
Old Jun 12, 2011 | 08:35 AM
Res1cue's Avatar
Res1cue
Default Dyno graph needed
Does anyone have a dyno of a Normally Aspirated 9.6:1 compression 402 Stroker. It has factory 243 heads and the cam in this motor is a 227/239 .613/.623 115LSA. Need dyno sheets for comparison purposes. Please post what ever your CR is. Hopefully your cam profile will be close.
Old Jun 13, 2011 | 06:36 PM
MARSC6's Avatar
MARSC6
Why such low compression for NA?
Probably why your not getting any responses.
Old Jun 14, 2011 | 08:49 AM
waddisme's Avatar
waddisme
Here is mine but CR is like 11.2/1. Cam is MS3 and heads were Patriot 2015s.
[IMG][/IMG]
Old Jun 15, 2011 | 06:46 AM
Res1cue's Avatar
Res1cue
Setup for a supercharger.
Old Jun 15, 2011 | 06:50 AM
Res1cue's Avatar
Res1cue
[IMG][/IMG]
Here is mine. Very concerned that the NA dyno was abnormally low but after looking at yours I am feeling a little better. Hopefully yours is not abnormally low as well. Also feared that the cam was slightly off. I have stock heads with 5 angle seat work.
Old Jun 15, 2011 | 07:55 AM
FloydSummerOf68's Avatar
FloydSummerOf68
~460rwhp with a heads/cam 402 seems really low to me
Those numbers seem like they would be on the lower side with just a heads/cam LS2 that wasn't stroked out.
Old Jun 15, 2011 | 10:02 AM
Streetk14's Avatar
Streetk14
I don't think your n/a results are off. Sure, it's a 402, but you are missing over a point of compression and have stock heads (and intake, right?).
I made about 20 rwhp more than you and the same torque with my cammed LS3. Cam was pretty close to yours (224/236) and I had 1.75" LG headers and a FAST 102 manifold at the time. But I had better heads and manifold and more compression, too. The only thing you really have going for that combo is extra cubes.
I've been watching your saga for the last year or more. Not sure what's going on now. All I can tell you is that my same motor combo from above (minus the FAST manifold) makes right around 10 psi with a T-trim and 3.6" pulley and stock crank pulley. Motor did 683 rwhp with 11.0 A/F and 14-15 degrees of timing, I think. That was with 100% M1 and 91 octane crap CA gas.
Hope you figure it out....
To Dyno graph needed
