DTC P2066 Fuel Level Sensor "B" Performance
Can anyone offer any advice about this?
I recently had to reset a DTC, P2066, to restore operation of the fuel gauge in my 2008 C6 (33k mi). I'm wondering if this is a common problem, if I can expect it to recur and if there is a reliable fix.
The fuel gauge dropped to empty during some aggressive driving on my favorite CA switchbacks with the fuel tanks about 1/3 full. Eventually the DIC displayed "Service Fuel System." Later, a scan revealed the P2066 Fuel Level Sensor "B" Performance DTC. Resetting it restored operation of the fuel gauge.
Thanks for your help, Huc
This problem always happens to the right tank because the right tank empties first. The level sender in that tank therefore spends most of its time un-immersed in gasoline, which is when they go bad.
If you examined the sensor contacts from both tanks you'd see the left ones were shiny and the right ones were dingy and grey.
Bad sensors also seem to work better when immersed, so the problem usually starts when the car approaches 1/2 tank. But eventually it gets worse.
You can pour a bottle of Techron concentrate in the tank for some temporary relief, but in my experience the problem eventually comes back.
The fix: drop the tank and change the sensor. And thereafter, make sure to fill up more often so the right tank doesn't spend a lot of time empty.
Given the number of complaints I've read about this problem, I'm very disappointed with Chevy's failure to develop a solution after so many years.
I’ve put well over 100k miles on each of several cars and trucks over the past fifty years and never had a fuel level transmitter or receiver fail before now.
Being a licensed control systems engineer and having developed complex control systems for major oil companies for a few decades, I would never have expected such a simple system to have such a high failure rate.
Having said all that, this ragtop blows the doors off of anything I’ve driven before. So I'll put up with dropping a tank now and then.
Btw, the error condition fallbacks on this car are ridiculous. One out of three throttle pedal sensors glitches for a moment - reduce engine power to 5% until you shut the car off; thermostat goes bad and slow to get up to temp - temp gauge goes to 0 and "engine overheating" screaming and never goes away till code is reset; one fuel level sensor glitches for a moment, fuel gauge shows empty forever...
I have used nothing but Chevron 94 for the past three years, and usually fill up when I get down around a quarter of a tank full. I'm going to run a bottle of Lucas Fuel System Deep Cleaner through the next fill up (can't buy Techron by the bottle in Canada), and I think I'm going to get in the habit of refuelling at the half full mark, just to keep the sensors constantly bathed in fuel. Can't hurt. Plus, I'm, I'm on my second fuel pump, no idea why the first one packed it in but keeping the tank half full may help keep the pump cool. It costs way too much money if you have to drop the tanks to fix these issues.
