2007 Coupe Electrical Problem
Old Jun 15, 2011 | 10:23 AM
steve9107's Avatar
steve9107
Default 2007 Coupe Electrical Problem
I have an intermittent electrical problem on my 07 Coupe. The fuel, oil pressure, active control, and coolant temp gauges all fail at once. Then, of course chimes start and messages scroll regarding low fuel, check engine, traction control/abs failure ect. Usually after 10-15 minutes of continuing to drive the problem resolves itself and all is normal again. Had the car to the Chevy dealer last summer = tech stated diagnostics indicates modules "blaming each other" for the problem. Tech asked I bring in when problem is occurring. Two days ago problem surfaced again, when I parked and shut off car for 15 minutes and returned - no start and check engine icon appeared. Back to dealer on a flatbed = car started second trial. Tech stated can't find problem as all checks out good with diagnostics. I agreed to his cleaning and lubing with conductive grease all 20 + module connections at a cost of $350.
Has anyone experienced this problem...does anyone have tips on a fix. This is getting expensive quickly!
Old Jun 15, 2011 | 10:28 AM
torquetube's Avatar
torquetube
You must first conclusively rule out a weak battery. Low voltage excursions will throw a million codes, even if the car is still able to start.
Old Jun 15, 2011 | 11:23 AM
RicK T's Avatar
RicK T
I agree, battery is "almost" always the first culprit to check. If your '07 is still on the original battery it's time to replace it. Please let us know what happens.
Old Jun 15, 2011 | 01:27 PM
cranky's Avatar
cranky
clean and check tightness of the bat + at the starter solenoid. check ALL grounds. you would be suprised at the ones i have fixed with problems at these connections...................
Old Jun 15, 2011 | 09:14 PM
steve9107's Avatar
steve9107
Thanks for the info Torquetube, RickT and Cranky. Got the machine back from the dealer tonight...runs fine SO FAR. The tech supposedly cleaned all module connections and applied dielectric lubricant. Also checked batt and starter solenoid terminals and all grounds. Battery check was very good. There is a service bulletin #09-06-03-004D regarding intermittent no crank/no start module communication, warning lights...diagnosing and repairing fretting corrosion on 2011 and prior GM passenger cars and trucks. Fix is to apply dielectric lube. We'll see if it works.
Old Jun 15, 2011 | 11:20 PM
DSOMC6's Avatar
DSOMC6
If the problem resurfaces check the starter selanoid to be sure the plastic around the terminal isn't cracked. After 3yrs or so the selanoid is toast from the heat. Most techs are too lazy to remove the exhaust manifold to actually view the starter up close and see if the selanoid is bad. They just stick a socket on the terminal nut to check if it's snug and then move on.
Old Jun 22, 2011 | 10:44 PM
TKrug007's Avatar
TKrug007
I have the EXACT same problem with an '08. It's at the dealer now. Once I hear anything I will let you know.
To 2007 Coupe Electrical Problem
