Z51 Rotor Question
Old Jun 15, 2011 | 02:04 PM
spender1326's Avatar
spender1326
Default Z51 Rotor Question
I need to do my front brakes. 05 Z51. I'm looking for any option. Has anyone tried these.
CENTRIC Part # 12862086L SportStop Drilled Brake Rotor
Z51 Package; Front Left
$102.79
Add to Cart
CENTRIC Part # 12862086R SportStop Drilled Brake Rotor
Z51 Package; Front Right
$102.79
This is from rockauto.com. Goto brake rotors - at the bottom.
We know that GM only has one part number for the front rotors. One side of the brake rotor is spinning the wrong way and decreasing cooling efficiency (I can't remember which side).
My big question is if these are two different models or castings, i.e. one made for the right and one made for the left side. They do have different part numbers. If this is the case case, then the price isn't bad for specific left and right rotors.
Does anyone have any experience with these? I've searched. Thanks.
Old Jun 15, 2011 | 02:23 PM
Gering's Avatar
Gering
Tolero Apto Victum
Just FYI, I have used these on my 07 Z51 and like them a lot, they are lite and last a long time. http://shop.performanceafx.com/C6-Z51-Corvette_c15.htm
Good Luck!
Old Jun 15, 2011 | 08:31 PM
Bill Dearborn's Avatar
Bill Dearborn
$102.79
Add to Cart
$102.79
How many miles do you have on your car? If the rotors aren't scored or less than the minimum thickness required why replace them? For street use with OEM pads the rotors usually last as long as it takes to wear out a couple of sets of pads. Driving on the street you will not see any differences if the rotors are curved the correct way or not. Most track drivers don't see a difference.
Bill
Old Jun 16, 2011 | 07:35 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
does rock auto have a toll free number? maybe you could call and ask them if the rotors are different side to side.
Old Jun 16, 2011 | 02:36 PM
spender1326
Bill
That's news to me... This will be my first set of pads, excluding OEM of course. My experience has been with Bimmers and Acuras. Everytime you changed pads on those cars, the rotors have to go because they made so close to the min thickness from the beginning. I'll mic it first before I go out and buy rotors. Thanks, you just may have saved me $200.
But, that leads to two more questions, is the min thickness printed on the rotor? Can you turn/grind the drilled rotors like a blank one? Thanks everyone.
Old Jun 17, 2011 | 01:47 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Unless your rotors are badly grooved or warped you don't need to turn them. Just clean them up with some sandpaper and install the new pads. I have an 06 Z51 and replaced my pads with ceramiks at 20K miles; didn't do anything to the rotors, just wiped en down. They are going great after about 15K miles.
Old Jun 17, 2011 | 03:14 PM
Austin-vette's Avatar
Austin-vette
St. Jude Donor '08
I do not remember exactly where it appears on the rotor, but it is easy to spot and it does specify the minimum thickness.
Old Oct 26, 2012 | 07:37 PM
67 fastback's Avatar
67 fastback
I've looked all over my factory z51 rotors sitting on my shelf for info..nada
Old Oct 26, 2012 | 07:53 PM
BEZ06's Avatar
BEZ06
The rotor discard thickness is in the Service Manual.
The service manual doesn't differentiate between any of the rotors on different models as far as runout, thickness variation, etc., and it says
New Thickness Front - 32 mm / 1.26 inches
Rotor Discard Thickness Front - 30.3 mm / 1.19 inches
New Thickness Rear - 26 mm / 1.02 inches
Rotor Discard Thickness Rear - 24.5 mm / 0.965 inches
Personally, I wouldn't consider "turning" or "cutting" rotors - I'd just get new ones if they're bad enough so that might even be necessary. The only reason that might be remotely necessary is if there are huge grooves on the rotor surface, but if they're that bad I'd just get new rotors.
Bob
Old Oct 27, 2012 | 01:31 PM
HOXXOH's Avatar
HOXXOH
The thickness limitation is stamped into the outer edge. You may need to clean or even use a little sandpaper to read it clearly. Run your fingernail over it to feel the location.
Make sure the guy that turns drilled rotors has experience doing them. The procedure is different than with plain rotors.
Old Oct 29, 2012 | 07:33 PM
67 fastback
Bob
1.22 1.23 fronts .99 for both rears I'll get them cleaned up hate having to budget right now. I miss the 2006 economy.
Old Oct 30, 2012 | 07:12 AM
Don 79 TA's Avatar
Don 79 TA
you got that right
not to mention its a **** on the cutting bits too
i did it a few times, takes a little while to cut them too
To Z51 Rotor Question
