C6 completely dead/dark
Old Jun 16, 2011 | 05:11 PM
broberts13's Avatar
broberts13
Cruising
Default C6 completely dead/dark
It did it again today. About the 4th or 5th time now.
2008 coupe, M6 tranny
I drove the car about 15 miles and was sitting in the car listening to the radio for about 5 minutes when I pushed the clutch in and pressed the start button and everything went dark and quiet, no relay clicks, no radio, no dash lights, no start switch lights. Repeated pushes of the start button did nothing. It is kind of embarassing when a pretty C6 is completely dead blocking a line.
I let the clutch out and put it back in and the ignition switch light came back on and it started.
Sometimes opening and closing the driver's door fixes it. Dealer never heard of it before.
All ideas welcome.
Old Jun 16, 2011 | 05:37 PM
akriggm's Avatar
akriggm
I'd check the battery cable connections - at both ends (and then have the battery load tested).
Enjoy,
akriggm
Old Jun 16, 2011 | 06:40 PM
torquetube's Avatar
torquetube
All ideas welcome.
As usual, you have to be certain the battery isn't bad before looking any further.
The starter can crank at a lower voltage than the computer requires to operate. A borderline battery can therefore keep the car from turning over, yet a minute later it will fire right up.
Old Jun 16, 2011 | 09:25 PM
VET4LES's Avatar
VET4LES
I agree with checking the battery first. A load test is the only way to find out if it's good. The other thing is to make sure your pushing the clutch pedal all the way down.
Old Jun 16, 2011 | 10:14 PM
C6topless's Avatar
C6topless
check battery first by having it load tested... that way you can see how it responds under duress... simply charging it may not give you a true picture if it is good or not.
next if the battery is good, check that you cables are making proper connection.. the design of the cables for that year tend to come loose.
if that doesnt fix the problem, have your alternator checked -- the standard corvette alternator puts out 145amps and tend to fail. if it has failed, go up to a 185 or 200amp
if the alternator is good, lift the corvette up and check the connection to the solinoid-- make sure you dont just visually inspect it .. reach up and see if that connection is loose. Also it might be the center plug (purple wire) in the solinoid as that is a common start problem in corvette.. i personally would swap out the plug style solinoid for the post style.
that is where i would start..
To C6 completely dead/dark
