3rd Gear Synchro
Old Jun 19, 2011 | 11:01 PM
jost6453's Avatar
jost6453
Default 3rd Gear Synchro
My 2011 GS MN has a less than perfect 3rd gear synchronizer. There's a small 'catch' or grind if I try to shift into 3rd too quickly. If I pause for a fraction of a second to let the synchro do its thing, the shift is smooth. Has anyone else experinced this problem? Is there a fix in the way of chemistry (additive or different tranny fluid)? Car has 1400 miles on it.
Old Jun 20, 2011 | 09:34 AM
Shifter6's Avatar
Shifter6
On my T56, 3rd seems a little notchy when shifted fast, but never grinds. I have found this to be the case on all C6s I have driven. My guess is that your trans is normal. See if you can find another 08+ C6 you can drive.
Old Jun 20, 2011 | 01:49 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
This is pretty common on the 08 up TR6060 transmissions. They are little notchy or have slight grind when cold. Once it warms up, it goes away. GM parts have changed the friction material to carbon on 2nd gear blockers only. I haven't seen the insides of the 2011 TR6060 (if first 4 gears have carbon blockers) but I think only the 2nd gear has it. I'll be upgrading a 2008 TR6060 with carbon blockers on first 4 gears shortly and I'll post the results.
__________________
Old Jun 20, 2011 | 02:11 PM
TripleAstyle123's Avatar
TripleAstyle123
I also notice this 3rd gear issue on my 08 z-51.
Old Jun 20, 2011 | 06:35 PM
gonezen's Avatar
gonezen
Ditto. New coupe, under 1000 miles. When cold it feels a bit notchy in shifting from 2nd to 3rd. At first I thought I wasn't depressing the clutch far enough but observation proved that thesis invalid. Guess we just live with it.
Old Jun 20, 2011 | 06:53 PM
vette6500's Avatar
vette6500
'05 Z51. i also have the same small catch/grind sometimes when shifting fast into 3rd.
i've had my trans rebuilt due to some broken ring that was causing big grinds, but it still has the small catch/grind when trying to shift fast (not necessarily high rpm it seems, just when rushed).
i figure it's my shifting technique (pushing of clutch maybe too early vs. pushing into 3rd?), since i see plenty of videos such as ranger drag strip runs where 3rd shift happen much much faster.
like you, as long as i give it that fraction of a sec more when shifting into 3rd, the synchros seem to be able to make up for my imperfect timing.
i've had GM fluid, Royal Purple Synchromax, then back to GM fluid after trans rebuild, but nothing can make up for my lazy/fast shifts.
Old Jun 20, 2011 | 11:06 PM
jost6453's Avatar
jost6453
Thanks for the input. Guess I'll live with it and hope it gets a little better with age. It's not that bad, just not as smooth as 2nd.
Old Jun 21, 2011 | 12:20 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I had a bad 3rd gear blocker ring in a rebuild...when I got it replaced my car shifts perfectly, better than stock (stock it was always hard to get it in first).
Your symptoms are not normal. A good rebuild doesn't grind. I had two bad ones and now have a good one. Might want to get it redone if still in warranty.
Old Mar 30, 2013 | 12:49 PM
c152pilot's Avatar
c152pilot
I am having the same problem with my stage 3 t56 rebuild. The guy who rebuilt the trans said to bleed the clutch? All the fluids have been changed out and my 3rd gear grinds at high RPM shifts only unless I pause for a split second. I am still under warranty and can now suggest that it could be the 3rd gear blocker ring.
To 3rd Gear Synchro
