Transmission Fluid
Old Jun 20, 2011 | 12:14 PM
Jim Snyder's Avatar
Jim Snyder
Default Transmission Fluid
Is Royal Purple Symchromax manual transmission fluid still good to use in my 2005 C6 transmission?
Old Jun 20, 2011 | 01:13 PM
GOLD72's Avatar
GOLD72
I am not an RP expert but I believe that is correct for the manual trannies. Be sure it is for DEXRON 3 applications. Do not use DEXRON 6 in a manual tranny under any circumstance. DEX 6 is only suitable for auto A4 & A6.
Old Jun 22, 2011 | 09:46 AM
jimfountain's Avatar
jimfountain
Default C6 Manual Transmission oil change
Is there a good thread for DIY? I searched and didn't find one.
Old Jun 22, 2011 | 12:18 PM
REVAK's Avatar
REVAK
I am using the sycromax in my 06 manual trans. You will need to raise the back end of your car, ramps work well. You will need a pump to refill the trans after draining. There are to plugs , lower plug is the drain, upper plug is the fill. I forget the capacity, its either 2 1/2 qts. , or 3 1/2 qts. [ sorry its been a while ]. There are pictures of this process on the forum, check the stickies, and re check or re word your search, you may find it that way. You can get an inexpensive hand pump at most auto supplies, I recommend the one that screws on to the quart bottle.
Old Jun 22, 2011 | 12:51 PM
GOLD72's Avatar
GOLD72
Manual trannies will take about 3.6 qts on a refill basis.
Old Jun 22, 2011 | 12:54 PM
LEAVINU's Avatar
LEAVINU
..... bone dry I think its like 4.1qts but I've never needed that much to refill. Make sure the car is fairly level when doing this obviously. I've been using RP in the tranny and diff since 2006.
Old Jun 23, 2011 | 07:31 AM
GOLD72's Avatar
GOLD72
I think you would have to go through a complete overhaul disassembly of the transmission to ever be able to fill it at 4.0 or 4.1 qts. I always level up the car the best I can when changing tranny & diffs. I have done maintenance drain and refills for two C5 Z06 trannys and one C6 Z06 tranny and never came close to using 4 qts.
Old Jun 23, 2011 | 09:25 PM
timd38's Avatar
timd38
Have you considered RedLine trans fluid?
It made my cat shift much smoother. That oil combined with an MGW shifter really made a difference.
Old Jun 24, 2011 | 07:18 AM
GOLD72's Avatar
GOLD72
I tried Redline D4 in my 01Z06 after 20k miles but really didn't notice a change in shift quality. I changed the 06Z06 to AMSOIL ATF also at 20k but also never saw any differences in shift quality. So IMHO, I wouldn't do a tranny fluid change for the sole purpose of seeking smoother shifting as I haven't personally seen it. But I did feel good at the time about changing the fluid to a full synthetic for both cars after 20k miles. As I remember, the factory fill DEX-3 was not a synthetic.
Old Jun 24, 2011 | 02:07 PM
JoesC5's Avatar
JoesC5
Shortly after I bought my 09 Z06, I decided something had to be done about the 1st & 2nd gear "nibbles" and sometime "crunches". I purchased the RP fluid and installed it and it made the shifting worse. I drained the RP(and cried,as the stuff is very expensive) and replaced with Mobil1 DexIII ATF. The Mobil1 restore the shifting to about what it was before the RP fill. Maybe a little better shifting but really difficult to quantify. Now at 15,000 miles, the shifting is better, but not by much. I suspect that the improvement is because the parts have worn in, not because the fluid works any better.
My conclusion is that changing the fluid is not going to solve the problem, maybe mask it a little. GM did make a change in the 2011 transmissions by going to carbon coated synchros to solve the problem. If GM could have solved the problem by changing the transmission fluid formulation they would have.
Old Jun 24, 2011 | 03:13 PM
Brandon619's Avatar
Brandon619
Wow, I thought those T6060 trans shifted like butter? If you think those trans are nibbly the T56 is very notchy compared to the T6060.
Old Jun 24, 2011 | 03:23 PM
Keith N's Avatar
Keith N
This is a DIY thread for the trans fluid change - Z06 - http://forums.corvetteforum.com/c6-z...-specific.html
I just changed the trans (T56) and diff fluids in my recently purchased 2006 Z06 with Royal Purple. It shifts much smoother and eliminiated the clunking noises from the differential.
Old Jun 25, 2011 | 12:08 PM
VIN1800's Avatar
VIN1800
Went to dealer and that's what they gave me was dex 6 for my 2007 manual trans. I told them it said dex 3 on trans, dealer said that's all they use. Should I change it? What will happen?
Old Jun 26, 2011 | 07:27 AM
VIN1800's Avatar
VIN1800
I went ahead and changed fluid and installed dex 3. For $18.00 for fluid and 15 mins labor, better to be safe then sorry.
Old Jun 26, 2011 | 09:53 AM
Ketchum's Avatar
Ketchum
www.amsoil.com Super quality,Big Brown delivers. Look up/Application guide. Become a preferred customer for a decent price break.
Old Jun 27, 2011 | 07:36 AM
GOLD72's Avatar
GOLD72
You did the right thing. My understanding is the new DEX 6 is too thin for manual transmissions.
Old Jun 27, 2011 | 12:05 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
GM maunal tranmission fluid is part # 88861800.
__________________
Old Jun 28, 2011 | 07:24 AM
GOLD72's Avatar
GOLD72
After the first year, they will likely offer you a multi-year membership renewal. At that time a couple of years ago now, I signed up for 5 years which drove the cost down to $16/year as I recall.
Old Jun 28, 2011 | 04:41 PM
Ragtop 99's Avatar
Ragtop 99
mine's like butter when warm, but notchy when cold. I used redline and that helped decrease the temp needed to not be notchy. Even with the Redline, on a 30* morning it takes a couple miles to feel right.
To Transmission Fluid
