Shifter Boot Cover
Old Jun 23, 2011 | 06:27 PM
Oldfly's Avatar
Oldfly
Default Shifter Boot Cover
For those of you that have installed a MGW shifter in there 2008 through 2011 car what did ya'll do about this cover did ya'll trim it or just leave it as is.
David
Old Jun 23, 2011 | 06:39 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
I trimmed with tin snips, however IIRC the isolator on my 08 was round, regardless, the hole was cut slightly smaller then the diameter then the shifter body so it fit like a glove.
Old Jun 23, 2011 | 06:43 PM
TxPres's Avatar
TxPres
I just left that piece out. Everything seems to work fine. No noise, no vibration, no increase in heat.
Old Jun 23, 2011 | 06:59 PM
///DarkSide\\\
Originally Posted by Oldfly
A circle cut around the base of that 1st inch of rubber & pull tight around body of shifter.
Old Jun 24, 2011 | 10:49 AM
Unreal's Avatar
Unreal
I followed the instructions that say to trim it.
Old Jun 24, 2011 | 12:12 PM
HalfMoon's Avatar
HalfMoon
The directions I got said to trim the lower cover. Note the holes in the OP's pic vs the tabs in the one on the MGW pics..
I trimmed the lower cover and manhandled the top cover on since that step was not mentioned in the instructions. This seems to "puff up" the boot, so i'm thinking about taking it off this weekend.
Old Jun 24, 2011 | 02:13 PM
Oldfly's Avatar
Oldfly
This is what I did to the lower boot. Its the upper boot I was concerned
about, that must be the one there referring to about cutting.
Old Jun 24, 2011 | 02:29 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
I'm getting ready to install on an 06, is this an issue for 2005-2007 vehicles too? I don't quite understand the problem; what interference does the boot present?
Old Jun 24, 2011 | 03:53 PM
Oldfly's Avatar
Oldfly
This is what the 2011 stock shifter looks like,
And this is what the MGW shifter looks like. So if yours looks like the above you will notice that the rubber boots do not fit the same, thus the trimming is needed. I believe the 08 through 11 are different than a 06 from looking at the installation CD that came with the MGW shifter.
Old Jun 25, 2011 | 06:34 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Did anyone try calling MGW to see what they recommend?
Old Jun 25, 2011 | 06:58 PM
Oldfly's Avatar
Oldfly
I did call George, and he told me to trim the peace in my above post where the razor blade is shown.
To Shifter Boot Cover
