Oil Analysis Not Good
Old Jun 24, 2011 | 09:38 PM
fnsblum's Avatar
fnsblum
Default Oil Analysis Not Good
Just received my second 5K oil analysis from Blackstone. Everything looks good except for a high iron number. You can view the report here. http://i1104.photobucket.com/albums/...lum/img012.jpg
Has anyone seen a number like this? Thanks. Frank
Old Jun 24, 2011 | 10:13 PM
LS1LT1's Avatar
LS1LT1
I'm surprised, Pennzoil Platinum is supposed to be pretty good, I just put it (10W-30) in my Camaro Z28 LS1 actually.
I use Amsoil in my C6 though.
Old Jun 24, 2011 | 10:32 PM
fnsblum's Avatar
fnsblum
The first 5K was Mobil 1. Don't think the brand of oil has any thing to do with it. Later! Frank
Old Jun 24, 2011 | 11:37 PM
SteveRiellyNZ's Avatar
SteveRiellyNZ
If I'm reading that right, is both Iron and Copper way out of the norm?
Were there shavings on the oil drain plugs? Shot in the dark, but are the levels up due to external contaminants in the oil, not the oil itself?
Old Jun 24, 2011 | 11:49 PM
fnsblum's Avatar
fnsblum
No metal particles on the plug either time other than the black oily residue that shows on the rag. Same stuff that shows on all magnetic plugs. I took the samples mid way through the oil drain just as I have on several other vehicles over the years. I am not too worried about the cooper because it went down. I have the Z51 package and understand there is an oil cooler. That might be where the copper is coming from. My Duramax was always a little high. Evidently there are not too many folks here that have their oil analyzed. Later! Frank
Old Jun 25, 2011 | 12:48 AM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Interesting. So far I've only done one oil analysis on my 06Z and I had elevated iron as well but not as high as your report shows - it was in the low 50s if I recall. Copper was fairly low. Blackstone indicated that, in my case, it was because the oil was in use fairly long - unknown mileage, oil monitor was at 10%.
Old Jun 25, 2011 | 12:18 PM
vettelover12's Avatar
vettelover12
2nd Gear
my cousin told me to start using this stuff. He swears by it.
http://www.amsoil.com/catalog.aspx?c...-EA&zo=1973595
not sure how to add links.. sorry.
Old Jun 25, 2011 | 12:46 PM
old motorhead's Avatar
old motorhead
Never considered doing an oil analysis on my vette because I've never had an oil related failure on any GM vehicle in 35+ years of running them stupid hard. I have had motor issues, but nothing an oil analysis would have prevented. What does the company doing the oil analysis say about your numbers?
Old Jun 25, 2011 | 12:54 PM
AirBusPilot's Avatar
AirBusPilot
For comparison purposes:
Old Jun 25, 2011 | 01:36 PM
fnsblum's Avatar
fnsblum
That has been the norm for all mine over the last fifteen years. Later! Frank
I must have had a senior moment when I typed the above sentence. I recalled later that the first time I sampled my 93 LT1 it was really bad also. The iron was 125 and copper was at 9. Three thousand miles later the numbers were 26 on the iron and 3 on the copper. I guess I won't worry about at this point. I am going to call Blackstone to make sure I took the sample right. Thanks for the replies. Later! Frank
Old Jun 26, 2011 | 12:17 AM
USAF-Vette's Avatar
USAF-Vette
Iron, aluminum and lead are elevated. Is this a forced induction engine? The iron is likely coming from the cylinders and it is specially high. Should probably be no more than 30ppm for that mileage. Copper is ok...these engines shed copper for years then settle.
Since the silicone is fairly low, I doubt you have bad filtration. Also, there is no antifreeze in the oil. This points toward a possible mechanical failure or extreme friction on the cylinders due to forced induction.
Rick
Old Jun 26, 2011 | 12:58 AM
fnsblum's Avatar
fnsblum
Since the universal averages are based on 4100 or 4200 miles aluminum and lead was not flagged. Car is stock.
Old Jun 26, 2011 | 01:02 AM
KFred's Avatar
KFred
How long have you used AMSOIL?
To Oil Analysis Not Good
